1. If the semi is using 2170 cells at this time, and we use old data (Tesla is likely more efficient now): The model Y long range uses 4416 cells to create a 75kWh pack. If the semi has a 1MWh pack, that's about 13 and 1/3 Model Y long range packs. So about 58,880 cells. Each cell weighs 68 grams. Total battery cells weight in this example is just over 4 million grams or about 8,827 pounds of battery cells. The Model Y long range motor weighs about 99 pounds. I couldn't find a weight for the carbon-wrapped motors, but assume it's slightly heavier so I'll estimate 100 pounds each. That bring the weight to 9,127 pounds for battery cells and motors. Add a few hundred pounds for housing / drive train components, but the question is where to draw the line to compare to removing the diesel engine and transmission. Some drive components may be similar / required in both. For this example, I'll round up to 10,000 pounds for the electric drive train. Perhaps that is low.
The average weight I found on Google for a class 8 truck diesel engine is 2,880 pounds. The figure I found for transmission weight is about 800 pounds. The fuel tanks typically have a capacity between 120 and 160 gallons. Some trucks have two tanks, so starting fuel could range from 120 gallons to 320 gallons. Fuel is consumed so weight changes during the trip. I'll target a value of 100 gallons of fuel to be conservative. Diesel weighs about 7 pounds per gallon, so another 700 pounds of weight for average fuel. That brings me 4,380 pounds for diesel drive train. I don't have a good idea of other components to factor in.
From that example, the EV semi would weigh about 5,600 pounds more than the diesel semi. I have no doubt Tesla did some optimizing on weight of the cab creature comforts and frame. The law allows EV semis to be 2,000 pounds heavier than a diesel semi. In a max weight scenario, and if my figures are close, then the diesel could haul about 3,000 more pounds of cargo than the EV semi. When fuel and maintenance costs are factored in, I suspect the EV semi becomes the obvious cost effective choice, even with a smaller cargo capacity, by weight.
I'm open to corrections for my estimates.
4. Elon previously stated they would have a 1,000,000 mile warranty (if I recall from the video years ago). It also has stronger windshield glass that is more resistant to breaking, less maintenance requirements, and will include Tesla's software safety features, which can help reduce liability / insurance costs.
