So you still didn't understand what I meant
When FSD is enabled, the FSD computer doesn't command a torque amount/pedal application, it tells the distance it wants to cover to the inverter and how to execute that, the inverter then checks the instructions, cross check with other systems, and if it's good, it translates the instruction to a sequence of torque/speed commands that completes the goal instructed by the FSD computer and executes it
My point is, selling FSD for third parties isn't bolting a few cameras and the FSD computer, it's way more involved than that. There isn't a port of even a instruction coming out of the FSD computer that is called "Thottle position"
You can't simply connected the FSD computer to any EV architecture, it's way more involved than that for safety reasons, it requires a ton of software integration to make it work, which we know OEMs suck at.
It can be done, probably will be done, the question is how? Tesla goes inside the OEMs to adapt the software? It isn't even inside the OEM since most use controllers/inverters from suppliers. Will Tesla supply the motor inverter part of the drivetrain? Just the know how and software?
