It's a 24K BTU MrCool heat pump, hopefully it'll work ok off-grid. If not, oh well.
Just to be clear, you keep mentioning "running off grid" but you will not be contacting your electrical utility and telling them to "come get your meter" if you have solar and tesla powerwalls. Essentially, its a grid tied system.
Its design is such that it will allow you to use your solar when the grid is off (if there is a power outage etc), but it is not an "off the grid" type solution. Also, if you have enough solar and batteries through (any weather and sun situation) in the winter, you will likely have a huge amount of over production in the summer. This only really becomes an issue depending on how your utility handles net metering.
In any case, you are likely aware of all this, but just wanted to make sure. As a point of reference, on my own system, I have a "negative grid draw" from about March 1 to about November 15, on a MONTHLY basis, however there are definitely days in there where that is not the case, because of weather. Also, from Nov 15 to Feb 28 my solar does not cover my home usage. Yearly, I end up close to "zero" but I dont consider myself to be "off the electrical grid".
I do enjoy looking at the daily negative numbers for most of the year, minimizing my dependance on my electrical utility, but its not "off the grid"
