Yeah, but most won’t take #2 or #1, which is why I said larger than.
What I was getting at is there only so many options since you tend to be limited both on both ends.
My bad, I was multi-tasking when I wrote that and I misread your comment. ;-)
That’s an odd duck. I wonder if an inspector would ever allow that. I don’t see much justification for that. What if you unplug or remove the load to be served? Now it’s an improperly wired receptacle. Normally with a single outlet it needs to do what it claims. A single 5-15 needs to be on a 15A circuit, but a duplex 5-15 can be on a 20A circuit...
I don't think the inspector could deny it really. They are supposed to enforce the code as written. I think this is very clearly allowed by the code. An extremely common example is a NEMA 14-50 installed on a 40a circuit. This is exceedingly common (and in fact is totally find for UMC Gen 2). I personally don't like it or think it is a good idea, but it is a common thing and is allowed by the code. :-(
Sorta. It depends on the type of cable. NM cable, which is what is used to wire houses is many cases is only rated at 15 amps at 75c.. THHN is rated at 20 amps, but that is before derating... because the only way to install THHN is in conduit, you will need to derate the wire that is installed in the conduit, which reduces the maximum ampacity below the 20 amps quoted in the chart you are looking at.
The wire ratings are the same whether NM or THHN (it is the same table in the 2017 NEC 310.15(B)(16)). It is referenced by wire size and type. What differs is what the insulation rating of the wire is and whether you are allowed to use the higher insulation ratings (NM cable is somewhat arbitrarily limited to the 60c rating in the NEC).
I am assuming you are referring to copper NM cable of 14 AWG in your comment. It is rated to 15 amps at 60c, 20 amps at 75c. So since NM cable is limited by code to the 60c rating, 15 amps is the max. THHN can also use the 75c or 90c column which is 20 and 25 amps respectively. The 90c rating is not practically usable since residential breakers and devices are generally only rated for 75c connections so that is your limiting factor. Note that all modern NM cable I am aware of and THHN cable are actually rated with 90c insulation (just you are capped by the artificial limit on NM cable to 60c and by the termination ratings to 75C for THHN). However: When you do derating for ambient temp or number of current carrying conductors in a raceway you use the 90c limit as your starting point.
Do note that THHN run in conduit does not need to be derated until you have more than three current carrying conductors in a single raceway. So to my point, 14 AWG copper in conduit is good for 20 amps as long as there are not more than three current carrying conductors in that conduit and the ambient temp is not over 86 degrees Fahrenheit.
Now, to my point, you still can't use that 14 AWG THHN in conduit on a 20 amp circuit due to those two asterisks in the table above. See 240.4(D):
Basically there are just hard limits on ampacity of these small wire gauges regardless of if the tables and deration factors would otherwise allow you to use them.
naw....
210.21 Outlet Devices.
(A) Lampholders.
(B) Receptacles.
(1) Single Receptacle on an Individual Branch Circuit. A single receptacle installed on an individual branch circuit shall have an ampere rating not less than that of the branch circuit.
(2) Total Cord-and-Plug-Connected Load. Where connected to a branch circuit supplying two or more receptacles or outlets, a receptacle shall not supply a total cord-and-plug-connected load in excess of the maximum specified in Table 210.21(B)(2).
(3) Receptacle Ratings. Where connected to a branch circuit supplying two or more receptacles or outlets, receptacle ratings shall conform to the values listed in Table 210.21(B)(3), or where larger than 50 amperes, the receptacle rating shall not be less than the branch-circuit rating.
Exception No. 1:
Exception No. 2: The ampere rating of a receptacle installed for electric discharge lighting shall be permitted to be based on 410.62(C).
(4) Range Receptacle Rating. The ampere rating of a range receptacle shall be permitted to be based on a single range demand load as specified in Table 220.55.
Table 210.21(B)(3) only applies to circuits with more than one receptacle on the circuit. Article 625.40 (EV Charging) actually requires that EV charging receptacles be dedicated and the only receptacle on the circuit. So we fall into 210.21(B)(1) which simply says the single receptacle on the circuit can not be rated to less than that of the branch circuit. Nothing is prescriptive here.
See my above post, NEC is very clear. You cannot put a 15 amp outlet on a 20 amp circuit. You can put multiple 15 amp outlets on a 20 amp circuit. You can put multiple 50 amp outlets on a 50 amp circuit. You cannot put a 30 amp outlet on a 50 amp circuit.
I think I was a bit misleading in my previous post about the 15a receptacle being allowed on a 20a circuit. I did not realize that allowance was under 210.21(B)(3), so if you only have a single receptacle on the circuit then you fall into 210.21(B)(1) and in which case you can not have a 15a receptacle on a 20a circuit. Good call out.
You can put multiple 50 amp outlets on a 50 amp circuit as long as it is not for EV charging (per Article 625.40).
And yes, +1 to your comment about not being able to put a 30a receptacle on a 50a circuit.
