The manual makes no mention of master or slave so that's a bad sign.
However, the web site says:
Wall Connector hosts a Wi-Fi network for easy configuration of breaker size, Wi-Fi connectivity, and power sharing. This Wi-Fi network is broadcast for five minutes after the Wall Connector is energized and can be re-enabled for an additional five minutes by holding the button on the handle of the charging cable.
The Quickstart Guide, included in the Wall Connector Box, has a sticker on the top of the front page with important information about this unique device, and should be kept with the owner after commissioning.
To connect to the Wall Connector’s access point with a smartphone or laptop, scan the QR code on the Quickstart Guide sticker, or manually connect to the Wi-Fi network with the SSID and Password provided.
After connecting to the Wall Connector access point, you may be automatically redirected to the commissioning wizard. If not, scan the QR code below or use your browser to navigate to
http://192.168.92.1.
So maybe you can change master/slave mode on the commissioning wizard.
Having only two rs485 ports doesn't prove it can't daisy chain with other TWCs by putting two wires in each port. The "in" and "out" ports on existing TWCs are mostly there for convenience of daisy chaining. The "in" and "out" sets are identical. You can plug into either one and there is zero resistance between the + terminals on in/out and - terminals on in/out.
I'll be receiving a gen3 in the next few days and let people know if it's still compatible with old rs485 when I get a chance.
Also, I committed a change to fix the display of multiple TWCs on the TWCManager web site.
