HX_Guy
Seems I'm having an issue...this status has been showing 0 minutes for about 45 minutes. Can anyone assist here?
screenshot windows 7
We would have to know your sleep settings and if Always Connected is on or off.Seems I'm having an issue...this status has been showing 0 minutes for about 45 minutes. Can anyone assist here?
@Jdeck With IFTTT support it would be possible to have a good source for info about wether the car is in use or not. There seems to be a feature request already for IFTTT (0000172: IFTT Integration - TeslaFi Bug Tracker), although it does seem to target another problem, if I get it right.
My idea is: the phone could report to IFTTT each connect and disconnect via bluetooth with the car. Then IFTTT could inform TeslaFi, which then could adjust the polling strategy.
It actually does look like a bug. You had Deep Sleep Mode enabled with a 0 minute 'try to sleep' time which essentially turned off polling completely during those times. It looks like the account setup script did not set the default time to 30 minutes so I changed it to 30 minutes and it's counting down now.
However, setting this 0 is not a bad option to keep providing I put some documentation in the settings and change the wording in the heading message. Basically if you set the Deep Sleep time to 0, it will completely turn off polling for that set time.
Love this idea! You should open a feature request for it.
Im still a bit confused on this Deep Sleep thing.
I have Always Connected to the "On" setting, so with that on, will the car go to sleep or not?
Deep Sleep Mode is the only mode that will work if you have always connected enabled. It will not officially go to sleep since the API will not return 'asleep' in the car's online state so TeslaFi can't track it. But as @msnow has reported and I've witnessed, it greatly reduces the vampire loss since it's only polling once every 30 minutes or depending on what you set it to.Im still a bit confused on this Deep Sleep thing.
These are my sleep settings:
image url
I updated it tonight. It needs a complete overhaul at some point. Lots and lots of tweaks and additions to that section over the months and it needs a fresh start.Thanks for the tip, Jdeck.
Going off what you said in the first part...so the settings of 30 means that TeslaFi will "ping" the car ever 30 minutes? And if I want to not poll at all during those hours, I should set it to 0?
EDIT: I should have read your description on the site better, looks like it's been updated fairly recently?
We can put it on the list but the problem is IFTT charges $2,500 a year now plus I'd have to find a lot of time to create an API for TeslaFi.
Are you configured for Deep Sleep or TeslaFi Sleep Mode?Hi, everyone, I have a new issue that might be related to TeslaFi... (probably not)
Yesterday I have a software update and installed version 2.52.22. My car is Classic and non-AP. Since then my car doesn't seem to sleep - in the Raw Data, I can see the car consumes -0.4A for SEVERAL HOURS, which definitely is not normal. Did somebody experience the same situation? No reboot yet but have driven the car 10 miles today.
Yes, I don't use Deep Sleep but enabled Sleep Mode. However I think the problem is that my car keeps drawing current for several hours... That way TeslaFi can't stop polling if Deep Sleep is not enabled.Are you configured for Deep Sleep or TeslaFi Sleep Mode?
Looks correct to me, let's see what James says. I assume you have "Always Connected" off (unchecked).Yes, I don't use Deep Sleep but enabled Sleep Mode. However I think the problem is that my car keeps drawing current for several hours... That way TeslaFi can't stop polling if Deep Sleep is not enabled.
Try a reboot. It looks like you did a software update yesterday which may have something to do with it. Maybe.Hi, everyone, I have a new issue that might be related to TeslaFi... (probably not)
Yeah I rebooted both center console and IC one time each, but it still keep consuming -0.4A all the time. Maybe Tesla is sending map updates for Japan cars over 3G? Will watch a few more days.Try a reboot. It looks like you did a software update yesterday which may have something to do with it. Maybe.
I noticed that my car sometimes idles for several hours with the battery current around -0.3A and TeslaFi doesn't try to let the car sleep. I'm wondering if -0.3A is normal idle draw when it's cold - just keeping the battery warm enough, maybe? What do you think about changing the battery current threshold to -0.5A instead of zero, to give the car a chance to sleep sooner in this situation?
