I've seen a few token tools that worked up until the weekend, the captcha itself wasn;t a problem for them, but the latest change seems more brutal reading the comments and I don't now if the Auth app would work with the lastest change by Tesla. What does seem to the case is Tesla are getting harder on this so it may only be a matter of time before they kill all 3rd party appsI started using that Auth app for Tesla (iOS) to log in. The author's last update suggests that there is no workaround for what Tesla are doing now, so that might be the only option.
Oh right, fair enough.. I'd used that app before last weekend, so if something has changed in the interim them I might be stuffed!I've seen a few token tools that worked up until the weekend, the captcha itself wasn;t a problem for them, but the latest change seems more brutal reading the comments and I don't now if the Auth app would work with the lastest change by Tesla. What does seem to the case is Tesla are getting harder on this so it may only be a matter of time before they kill all 3rd party apps
Same for me - no data since 1st Sept, tho I haven't used the car that much so only noticed it on Monday 6th. I fixed it by logging in using tokens rather than email and password. See the previously posted link for a solution using an app to get the API token etc - it worked for me, though I'm a bit concerned for how much longer it will continue.all my car data has stopped going to Teslamate for the last week.. had been working fine for a year.. now nothing!
I've changed nothing at my end....
Yeah, it would be nice if TeslaMate could notify you if it had an issue authenticating...Same for me - no data since 1st Sept, tho I haven't used the car that much so only noticed it on Monday 6th. I fixed it by logging in using tokens rather than email and password. See the previously posted link for a solution using an app to get the API token etc - it worked for me, though I'm a bit concerned for how much longer it will continue.
Error: mfa_input_not_found / Recaptcha is required · Issue #1945 · teslamate-org/teslamate
After setting up teslamate v1.24.0 as per the documentation, attempting to sign in with either my main Tesla account (which has MFA) or a secondary I set up with access to the vehicle (with no MFA)...github.com
Mine is working ok and I switched vm too.Could this issue with no data be related to changing of the Google virtual machine?
I too have no data from teslamate since 30 aug when I switched vm
Thanks so it wasn't me.Mione's all fine too, both before and after the VM switch.
Check the log files for clues. "docker-compose logs teslamate"Thanks so it wasn't me.
Any ideas what to do to fix it. Not a docker user so I followed Dave's instructions blindly and surprised myself! Now lost as to what to do to fix
This! I'm also using a google vm and the change to the new machine type is nothing to do with the Teslamate authentication issue.Log out and use token?
Can you share the code for the dashboard?Updated my history/overview dash with a few more custom panels. Happy to share the json code if anyone wants to add any to theirs.
