Tire pressure warning calibration?
Discussion in 'Model 3: User Interface' started by Nikola M3, Nov 12, 2018.
  1. Nikola M3
    Nikola M3 Member
    so cal
    #1 Nikola M3, Nov 12, 2018
    We drove up the mountain where the altitude and cold changed the tire pressure, on the way back we got a warning for the front left. It is really strange since the front right is lower but it isn't colored for a warning. Before we left the pressure was 42 all the way around.
  2. gaswalla
    gaswalla Model S,3,X.. CT with Austin delivery
    San Diego
    Same thing happened to me last week in the morning. 39 psi isn't that low anyways - odd
  3. Nikola M3
    Nikola M3 Member
    so cal
    You had a lower reading that wasn't flagged?
  4. BobChaput
    BobChaput Member
    Durango CO
    Not quite sure this is the place to post this issue.
    Yesterday I updated to 2018.42.2.1. I'm getting a new alert sound that I haven't had before.
    I suspect this is a low tire pressure warning. It was very cold this morning. I no longer get the low tire pressure indication even though my current tire pressure is "low." Is this the new way of announcing tire pressure.
    The sound is like a ring rather than a tone.
  5. okashira
    okashira Member
    What. I'm at 35/36 psi with no warnings at all, and happy about that.
  6. Knightshade
    Knightshade Well-Known Member
    NC
    I had something similar this weekend- at 42 psi... and with it warning for one tire at 42, but not the one on the other side at the same pressure.
    (this was in mid-40s temps, also driving up a mountain though not a huge one)
  7. MP3Mike
    MP3Mike Well-Known Member
    Oregon
    I wonder if it only highlights the first tire that triggers a low pressure warning.
  8. Nikola M3
    Nikola M3 Member
    so cal
    No, when coming down the mountain it showed 3 tires highlighted, then 2 of them went away. What was odd is the one left was higher than the ones that cleared.
  9. outdoors
    outdoors Always roaming
    off grid till Xmas
    Check tire pressure x2. Alternates with tire pressure too low. Why the 40 but not the other 2 39's?
  10. ViperDoc
    ViperDoc Roadster 1305
    Vermont
    My snow tires went on the Model 3 yesterday. Today, it was giving me the "Tires very soft x 4" error, and it showed all 4 tires read 35 psi. Well indeed they did, because that is what they were inflated to by the service center. So I inflated them up to 42 psi. Strangely, now I am still getting the error that says the tires are low, even though all 4 are reading 41 psi!
  11. ezevphl
    ezevphl Member
    Philadelphia
    Got the same warning last week. It was only for one tire for multiple days. Then temps dropped a bit more and I saw it for several tires. I inflated all of them to 42 and the warning went away. It really didn't make sense as some of the ones displaying a warning were actually 1 or 2 higher than the ones with no warning.
  12. Tootallal
    Tootallal Member
    Augusta GA
    Same here. Right rear quite often reads one pound less than the other three. 38 psi seems to trigger the notice.
  13. frank69
    frank69 Member
    Los Angeles
    Same here...front right got the warning ....it just went away. And my tire pressure is the same. Go figure the glitches..
  14. FinallyGotMyM3
    Menlo Park, CA
    Same thing started happening a few days ago.
  15. ezevphl
    ezevphl Member
    Philadelphia
    Its almost like there are two separate sensors.. one measures the actual pressure, one is just low/good.
  16. Refurb
    Refurb New Member
    SoCal
    Same here, and the warning will not go out even when the tires warm up and the pressures are all 40+. Even going into park makes no difference. Has anyone called support for htis? Any solutions?
  17. gern
    gern Member
    San Jose
    This happened to me yesterday (warning came and would not go away even after all tires reported 40+ psi). I found doing a power off (from Controls->Security) cleared the warning on my car.
  18. BioSehnsucht
    BioSehnsucht Model 3 LR
    DFW, TX
    I had this happen today (started "low" at mixed 41/40 - though only 41's were indicating low, all warmed up to 42 after driving on highway). After stopping, getting out of the car, eating lunch, and returning to the car, it seems the warning went away. I suspect that it only clears the alert after the vehicle is "turned off" (i.e., parked and you leave it alone), even if the actual tire pressures are shown as normal.
  19. Zeronet
    Zeronet Member
    Flagstaff, Arizona
    I "commute" every few days between Sedona (elev. 4600') to Flagstaff (7000'). Then I drive to Tucson (2800') every couple of weeks. A couple of weeks ago when it started getting cold, I started getting this annoying low tire pressure warning while in Flagstaff (38 psi when cold). From what I have read about elevation, my "real" pressure at 7000' is about 4 psi higher than the sensors indicate, or at a good 42 psi value, like I have in Sedona. I don't want to change my tire pressure twice a week just the keep the inaccurate tire sensors happy.
    So, is there any way to reset the sensors, or get the Tesla to incorporate altitude into its software?
  20. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    #20 ecarfan, Dec 12, 2018
    I got the low pressure warning multiple times over the past 2 weeks when the pressures in all tires decreased to 39psi or less. I am at 500 ft above sea level and air temps have been 45 to 55F: obviously not “real” winter.
    Yesterday with the tires cold I pumped them up to 44-45psi, verified that my tire gauge matched the pressures the car display (within 1psi) and the warning has gone away. I realize that Tesla recommends 42psi cold tire pressure. I may drop my pressure down to that, but wanted to try the higher pressure first as an experiment. 44-45psi cold won’t hurt the tires; the tire sidewall label states the max pressure is 51psi. At this time of year they will never get that high even if I drive all day.
    Yes, at the higher tire pressure the ride is not as smooth, but I don’t mind. It’s better than having the low pressure warning always on.
    I expect that in the future Tesla will modify the firmware to allow for some flexibility in when the warning is displayed. For now you will just have to live with the warning or add air.
