Tire wear
Discussion in 'Model S: Driving Dynamics' started by odguy, Jul 10, 2017.
  1. odguy
    odguy Member
    Wisconsin
    Question regarding tire wear. I'm in AWD 60D on original goodyear tires over 12K miles and the rear tires have worn more than the front. Is this typical? I almost always have range mode off, don't drive aggressively but do floor it occasionally. I would estimate more highway driving slightly.
  2. fasteddie7
    fasteddie7 Member
    uniontown PA
    About right. 12,500 miles on mine and I needed a new set of rear tires. Par for the course.
  3. rdr1rx
    rdr1rx Member
    Bay Area, CA
    Goodyears imply that you have 19s with a square setup. Then yes, typical for more rear tire wear because you didn't mention rotation at the recommended 6,250 mile interval on those original tires.
    However if you did rotate at that mile marker, then no, atypical because wear should be fairly equal. If rears are worn more than the fronts with a rotation, I'd suspect an alignment and/or air pressure problem.
  4. odguy
    odguy Member
    Wisconsin
    Thanks for the responses. Yes correct 19s, was planning 1st rotation yesterday at Costco but didn't realize I needed this lug nut cap removal tool. He said he could remove with pliers but risk braking them.
  5. scottm
    scottm Version 9 software sufferer
    Canada
    lug nut cap removal?
    Is this some cap you've added to the OE design?
    Don't be pulling apart OE lug nuts.
  6. Max*
    Max* Charging
    NoVa
    I think it's abnormal if you need to replace them already.
    70D, 19", 41k miles and I'm down to ~3/32s. I'll replace them before my next long trip.
  7. odguy
    odguy Member
    Wisconsin
    This is the specific tool: Tesla — Lug Nut Cap Remover
    Just to remove the cap over the lug nut.
    Was planning to rotate not replace, just thought front would wear faster than rear in AWD.
  8. st50maint
    st50maint Member
    New York
    At 26,000 miles I had the first tire rotation on my 2015 70D.
    The front two tires were worn down to 7/32.
    The left rear was at 6/32.
    The right rear was at 5/32.
    The tires were not rotated at my first annual service (12,500 miles) because Tesla said all tires were evenly worn.
    I asked the service advisor why the right rear was worn so much. He claimed that the right rear is where the most power is applied.
  9. Venomboy
    Venomboy Member
    Bay Area
    Just took mine in for a rotation. 2017 90D with 8000+ miles. Fronts at 8/32, rear at 5/32. Service guy told me he's seen most people needing new tires around 15k miles. I don't drive crazy or too fast. Hopefully I'll get more mileage out of these.
  10. scottm
    Canada
    100,000 km on RWD car, swapping out seasons for tires, still on original set of Michelins.. but this will be their last season.
    I have been so looking forward to turning off Traction Control and lighting 'em up in smoke at the end of this summer... then rotating them... and doing it again!! Just before I put the winters on.
    A lot depends on how you drive and how you like to drive and how much you're willing to pay for driving like that... enjoy!
  11. mrjedistud
    mrjedistud Member
    New York
    I usually just use my fingers to remove the plastic caps.
  12. paperjohn
    paperjohn Member
    Santa Cruz Mountains, CA
    2016 MS 90D
    Never rotated, even wear
    Goodyear 19"
    Changed out all four at 24500, with more Goodyears.
    I think I could have gotten 27000, but had a bad puncture(pencil size hole), so changed them out early at my 25000 mile service.
    Some mountain driving and lots of freeway driving
