Toolbox 3 Gateway Configuration Edit on Model 3 / Y?
terranx
3,113
4,210
Anyone out there know how to do this? As best as I can tell, the menu the tesla techs use (something to the effect of dashboard -> infotainment -> vehicle configuration change) isn't present in the version of toolbox us mere mortals get access to. However, under actions, PROC_ICE_X_SAFE-SET-VEHICLE-CONFIGS is available. The parameters it accepts are ConfigParams (type List) and Configs Require Ice Reboot (presumably yes/no, true/false, 0/1, etc -- can be left blank though I believe).
From what I can tell digging through the app.f5d3cbaebb2ad903a936.js file, this action is what's invoked when making the gateway config changes the official way. I just can't figure out how to format the input. For example I'm trying to change id 32 to 01, and I've tried sending {32, 01} and many variants (with quotes, different brackets, etc), to no avail. I mostly get an error about not being to cast the input as a List.
Anyone out there know what to do or can help with some hints? I can share any other relevant info
Reactions: WhiteM3P-
No dice. ValueError('Could not typecast root[32]=01 to List')
What I've been able to determine so far:
If I enter [] or {}, the function runs, but ultimately errors out saying it couldn't update the vehicle configuration (presumably because I'm passing a blank list).
Any of the below it doesn't even get as far as trying to execute anything and I get the noted errors
{32}
description:"AttributeError("'int' object has no attribute 'get'")"
{'32'}
Error: AttributeError("'str' object has no attribute 'get'")
{32,01}
Error: ValueError('Could not typecast {32,01} to List')
{'32','01'}
Error: ValueError("Could not typecast {'32',01} to List")
{32},{01}
Error: ValueError('Could not typecast {32},{01} to List')
{32:01}
Error: ValueError('Could not typecast {32:01} to List')
[{32}]
"ValueError("ScriptTest inputs and outputs must be (<class 'str'>, <class 'int'>, <class 'float'>, <class 'bool'>, <class 'dict'>, <class 'list'>, <enum 'Enum'>)")"
Errors are essentially the same if I used [ ] instead of { }
Not really sure what else I should be trying. A part of me wonders if the browser isn't passing parameters properly and I need to figure out how to invoke the command via console.
Upvote 0
Yeah I think it's a relatively low level thing. The interface the techs use calls it at the backend.
Digging through the javascript, I think the console command is supposed to look something like
Code:
send_network_request({"command":"execute","args":{"name":"Model3/tasks/PROC_ICE_X_SAFE-SET-VEHICLE-CONFIGS","kw":{"configParams":{"configid":32,"data":"01"},configs_require_ice_reboot":null,"ignore_display_state":true,"skip_gtw_state_checks":false}}})
Sending that from the web console on 192.168.90.100:8080 fails due to a token error, even when connected
Attempting to send the command from the actual toolbox tab doesn't work since the whole thing is obfuscated (though could maybe figure out how to do it with some debugging). Attempting to pass the commands through the actions interface doesn't work, but I'm starting to think that the text parser is semi broken for more complex commands
Reactions: strm and WhiteM3P-
Upvote 0
Just to close the loop, the correct syntax is
Code:
[ {"configid":32,"data":"01"} ]
. Credit to green for the info.
Unfortunately Tesla has this sufficiently locked down that we can’t edit the options that actually interest us. Service center might be able to if you can convince them to try.
It does appear there are methods to get access at a lower level, but none are publicized.
Upvote 0
does someone know what configid is what for?
Code:
7:"06"
8:"01"
9:"00"
10:"03"
11:""
12:"01"
13:"01"
14:"01"
15:"02"
16:"7A"
17:"09"
18:"00"
19:"00"
20:"01"
21:"01"
23:""
24:"01"
25:"01"
26:"01"
27:"01"
28:"02"
29:"04"
30:"02"
31:"01"
32:"02"
33:"00"
34:"01"
35:"03"
36:"04"
41:"16"
42:""
43:"02"
44:"01"
45:"01"
46:"01"
47:"01"
48:"00"
49:"00"
50:"00"
51:"01"
52:"01"
53:"01"
54:"00 00 00 00"
55:"00"
56:"01"
58:"01"
59:"04"
62:"02"
63:"01"
64:"00"
66:"01"
67:"02"
72:"00"
73:"02"
75:"01"
76:"01"
Upvote 0
Code:
7:"06"
8:"01"
9:"00"
10:"03"
11:""
12:"01"
13:"01"
14:"01"
15:"02"
16:"7A"
17:"09"
18:"00"
19:"00"
20:"01"
21:"01"
23:""
24:"01"
25:"01"
26:"01"
27:"01"
28:"02"
29:"04"
30:"02"
31:"01"
32:"02"
33:"00"
34:"01"
35:"03"
36:"04"
41:"16"
42:""
43:"02"
44:"01"
45:"01"
46:"01"
47:"01"
48:"00"
49:"00"
50:"00"
51:"01"
52:"01"
53:"01"
54:"00 00 00 00"
55:"00"
56:"01"
58:"01"
59:"04"
62:"02"
63:"01"
64:"00"
66:"01"
67:"02"
72:"00"
73:"02"
75:"01"
76:"01"
Most of them are in here { "gen3": [ { "accessId": 7, "codeKey": "exteriorColor", - Pastebin.com
Upvote 0
I haven't yet. It's a side project that I have not had time for. The thought was to modify one of the cheap speaker activation harnesses and wire the car exactly like the LR with all front speakers coming off the front amp, run the two wires for the a2b protocol to the trunk for the rear amp for the rear speakers. Then edit the config file on the MCU to tell it it's the premium version.
Upvote 0
Has anyone with toolbox gave this another try yet?
I haven't bought toolbox in a while, but I've been keeping an eye on the javascript source, which seems to show which roles can edit which functions. So far tbx-external is showing the following for the 3/Y/Refresh S/X
Code:
"coolantpumptype","ecallenabled","forwardradarhw","packperformancedeviation","powerliftgatetype","steeringcolumnmotortype","supermanifoldtype","towpackage","tpmstype","twelvevbatterytype"
Does seem like a team managed to get root access via an unpatchable vulnerability on ryzen cars Unpatchable AMD Chip Flaw Unlocks Paid Tesla Feature Upgrades
But taking the computer out and executing a glitching attack isn't trivial for most of us. But perhaps smarter folks having unpatchable root access will make it easier for them to find software vulnerabilities.
Upvote 0
