Hi folks, been looking at charging, cables, etc and I'm a little surprised or just not getting it...
Looking at the Tesla website, it says the Model 3 comes with a Type 2 cable that has a max charge rate of 11KW. Looking around at public chargers I see that they can offer much higher charging rates than 11KW, on Zap Map I see loads of 22KW type 2 connections and some at 43KW.
Now from what I've seen in the flesh the 22KW ones you have to use your own cable and the 43KW ones are tethered.
Thus if I take the Tesla supplied cable and plug it into a 22KW public charger then seems I'll only get 11KW max due to the cable limit?
Plugging into a 43KW point with a tethered cable, will I get all 43KW or thereabouts (depending on charge state, temp, other cars sharing the charger etc). Or am I going to be limited to 11KW on a type 2 connection regardless because of the car?
I know it will charge much faster on CCS and Tesla Supers but what about the 22KW and 43KW type 2 which are more common? Is Model 3 limited to 11KW on these connections regardless of the supply?
Help!
Help!
