Around 35 minutes.Anyone’s update taking an age to install? Started at 7:30… I need to leave the house at 8:45
Updates usually don’t take this long?
EDIT: convinced Tesla gods are reading. Just finished now, jumped from 60% to 100% in a minute or so
I'm just installing 14.8 now and had hoped it would fix the indicators which have had a habit of failing to cancel since the last update. Looks like I might be out of luck.Installed the following 2 days ago in my M3H RWD- v12 2024.14.8
Since then no emergency breaking, cruise control doesn’t work, indicators don’t switch off after changing lane, no detection of white lines and steering correction.. there may be more.
Not great TBH.
Are you trying to use them as "3 blink" mode? (whatever that is called)I'm just installing 14.8 now and had hoped it would fix the indicators which have had a habit of failing to cancel since the last update. Looks like I might be out of luck.
Got it this morning. I’m sure it won’t be long for you now.Anyone else with a 2024 Y still yet to receive this?! No manner of wake ups, charges, or two-button reboots are making this available to me!
The indicator issue is due to the setting under the lights menu for indicators being set to auto by the update. Turn that off to return them back to the previous behaviour.Since then no emergency breaking, cruise control doesn’t work, indicators don’t switch off after changing lane, no detection of white lines and steering correction.. there may be more.
Good because my summer holiday starts on 1st June . Still no sign of it here yetCertainly seems 14.8 is on a big push, and I’ve also seen it mentioned on Twitter with the comment effectively saying the spring update to be out for all in spring.. ie before June
not sure pulling down to refresh would help. refresh only works after 24 have passed since the last check. happy to be corrected here.I think I polled the refresh updates too many times! Still nothing for me and I used to be in the early batch.
Also as part of the hot weather HVAC improvements, I was hoping to see something smart, like A/C turning off automatically when I open my windows but seems that's a bit too much to ask at the moment..
I feel your painstill nothing for me, I've gone from being one of the first to get updates to one of the last!
I think the issue affects either state. The 3 blink mode seems to need to be cancelled after say leaving a roundabout when previously it would stop as it should, on roads I have driven many times without this behaviour. Likewise on a 'hard' signal when you push the stalk all the way down sometimes it cancels and sometimes it doesn't.Are you trying to use them as "3 blink" mode? (whatever that is called)
If so, you're probably a victim of Tesla having turned on "Auto cancel" for everyone. This feature will make single pull indicators keep blinking until the car thinks you've done the manoeuvre, whether that be changing lanes or whatever.
so why are you still following Tesla posts then? just kidding .It seems that Tesla continue to have big problems with software updates, wipers, indicators etc and not too mention removing stalks! I am so pleased that I sold my M3LR a few months ago and now await my new BMW i4
