US Oil & Subsidies
Discussion in 'Energy, Environment, and Policy' started by hcsharp, May 1, 2012.
  1. SageBrush
    SageBrush 2018: Drain the Sewer
    New Mexico
    "Help" is a political statement. Academics is a pursuit of knowledge and understanding. They contribute all the time ... when people are ready to listen.
  2. nwdiver
    nwdiver Well-Known Member
    United States
    Save your breathe. The morons of the world will only be convinced there was a problem once everything is burned to ash. It's pathetic. You can't fix the stupidity of locked ideology.... meanwhile the world burns. Truly pathetic. They betray their families, their country and the planet... for what? A fancy loud car? It's sick.
    Too bad the climate doesn't have an 'ignore' feature....
  3. lklundin
    lklundin Active Member
    Munich
    I am projecting the effects of the last 18 months of the uncapped, decreasing federal tax credit, you are apparently commenting on something else.
  4. rays427
    rays427 Member
    Penn Valley, CA
    No I don't think there are 130,000 professors in the field but that means there are some making a bit more than $100,000. My actual point is $13 billion spent on climate change research is by no means chump change. It shows that pushing climate change disaster is very lucrative.
  5. SageBrush
    New Mexico
    Look up Prof salaries. Go on, I dare you.
    Are you really so deluded that you think the Trumper talking point is money in their pockets !?
    I'll bet a handsome sum that the $13B is the total federal involvement in Atmospheric and Earth Science research ... if not other things thrown in too.
  6. rays427
    rays427 Member
    Penn Valley, CA
    I agree there is global warming but I don't believe it is all caused by man and don't think it will be catastrophic. As and example take a look back to the 1930's it was as hot or hotter in the US than today. So what caused the increase at that time? By the way here is the history of wildfires in the US: National Interagency Fire Center. Please note that the amount of acres burned in 1930 was about 5 times what burned in 2017. Not only were more acres burned but there where more fires in the past before the rapid increase in CO2.
  7. SageBrush
    New Mexico
    It is overwhelmingly fossil fuel combustion driven and IT WILL be catastrophic. It already is, and it is going to get much worse. Year by year, with very little respite ... perhaps just enough to keep the denialism going for a while longer.
    Your opinions about AGW are about as informed as your presumption that $13B a year is spent by the federal govt on AGW researcher salaries.
  8. Brando
    Brando Active Member
    Bainbridge Island, WA
    Sadly many of those fires started by people desperate for jobs - fighting fires - we had more forest then and I'm still not sure more. Sure we have less forest now than 1930s anyway. yes, complex - sadly living on a very small farm (no the sad part;)) loss of bees, hummingbirds, small birds, insects - even ant populations down - how can that happen?? NO chemicals (nor fertilizers) used here for at least 18 years. scary.
  9. rays427
    rays427 Member
    Penn Valley, CA
    Here is the History of spending on Climate change per the GAO. (Key Issues: Climate Change Funding and Management) Notice on the graph that most of the amount is for science and technology. I guess it depends on what you consider research. In addition per the GAO expenditures in 2017 were $13.2 billion.
  10. nwdiver
    United States
    #70 nwdiver, Aug 27, 2018
    Cognitive dissonance and ignorance; the true antidote to anything even remotely resembling intelligent thought or critical thinking.....
  11. Brando
    Changing the oceans for better or worse takes a long time. Not really sure how will help oceans return to lower acidity and lower temperatures - very depressing. Orcas and Salmon and Oysters/Clams and starfish are the most obvious losses here in the Puget Sound. But all sea life way down including Kelp.
  12. TheTalkingMule
    TheTalkingMule Distributed Energy Enthusiast
    Philadelphia, PA
    Always amazes me to hear someone say they "believe" that the planet is warming(as if actual measurements of temperature are subject to belief or disbelief), but that it's certainly not man-made. I have much more respect for folks who feel the base measurements are a fraudulent conspiracy.
    CO2 is a greenhouse gas. Our entire human society is currently based on emitting CO2. I think it boils down to human beings inability to fully fathom what 840,000,000 gallons of crude oil PER DAY looks like. That's a lot of CO2....just from oil alone....every day.....just in the US.
  13. darrelld
    darrelld Member
    North Texas
    The Military Cost of Defending Global Oil Supplies
    At minimum, approximately $81 billion per year is spent by the U.S. military protecting global oil supplies. This is approximately 16 percent of recent DoD base budgets. Spread out over the 19.8 million barrels of oil consumed daily in the U.S. in 2017, the implicit subsidy for all petroleum consumers is approximately $11.25 per barrel of crude oil, or $0.28 per gallon. A more extensive estimate by two highly-regarded economists suggests the costs could be greater than $30 per barrel, or over $0.70 per gallon.
