Isnt it possible to just wire L1-L1 and L2-N on the wall connector, like in the attached diagram (from the US manual). If ground is missing, just burrow a grounding spear. Thats how its done in Norway for Isolated Terra (IT) nets.
I have 600kVA 240 grounded B service at work and the only place the ground connection happens is after the POCO's CT on the bus bar.
if it weren't for everything being in EMT/rigid conduit, I'm pretty sure the previous tenants would've tried to ground another phase somewhere. I wouldn't want to have to change it to anything else. it would be quite the ordeal and after I'd have no additional function added.
I have a similar issue with an existing large 480V 3W to 120/240V 3PH center tapped transformer. I have multiple car chargers to hook up and all the manuals i read say i cannot use the the L3 leg as the voltage is 208V to ground, not 120V.
