So it's likely that the battery won't degrade any more? Usually with batteries in things like computers and stuff, it will keep degrading until it has difficulty holding a charge and will just suddenly shut off at 20%. Is it wrong to assume that with a Tesla battery?
I will try to make an answer that covers a few things:
I’m from Europe and googled the North Carolina climate. It seems quite warm (?)
A large portion of the degradation comes from calendar aging. Calendar aging increases with:
-High temperature.
-High SOC.
With the car outside in the sun the battery will be warmer than the ambient, perhaps 5C or 10F. Charging also increases the cell temp, as well as driving it.
A car that was parked outside might have a average temp that’s 5-10C above the ambient.
We can calculate a calendar aging/degradation on the battery.
In the central North Carolina the annual average is 19C, so just for making an example we can use 30C as the annual average cell temp.
At 80-90% SOC the calendar aging for 10 months will be about 6.5% which will be about 7% for the first year ( square root (12/10) x 6.5).
Calendar aging reduces with the square root of time so this will be the total calendar aging (rounded numbers):
After one year 7%
After two years 10%
After three years 12%
After four years 14%
After five years 15.5%
After six years 17%
After seven years 18.5%
After eight years 20%
After 16 years 28%
To the numbers above we need to add the cyclic aging which is much less. The standard range will have bigger average dept of discharge than a Long range that cause more cyclic sging but still we could set it to approximately 1% each year.
So this answers the question if the battery will continue to degrade; yes it will but at progressively smaller rate.
Also, in all lithium battery research the degradation is very foreseeable and follows the known degradation rates. This is even for single cells and the variation of degradation between single cells is some 1% or so.
A big pack with a lot of cells will follow the known rates.
“The battery lottery” is not really existing when it comes to degradation. For some part maybe one car may start slightly below another, but mostly it will be a BMS estimating error that we see.
You will not find a three-four year old SR+ ifrom north carolina with a true degradation of only 5%. There might be one with the BMS fairly off stating that but a real degradation test would show up closer to the numbers above.
