In another thread a member asked about how much vampire drain is caused by 24x7 (always on) use of a dual-channel (2 camera) dash cam.
That led me to do a controlled test where I left the car unplugged on two separate trips (one 4 days, the other 3 days). One trip had the dash cams running as I normally do. The second trip I unplugged the dash cams before I left to compare the results.
I have a Blackview DR650S-2CH and a Tesla Model S 75D. My starting target charge is about 212 (341 km) miles in both cases. My car is parked in a non-insulated garage and the temperatures there (in moderate California climates) were probably in the 50s (F) at the lowest. Garage doors have glass in them so the camera is semi-active detecting “movement” from headlights that shine in from the street from passing cars. Not constantly but the cameras are periodically active at night.
I took before and after photos of the remaining miles in the car at the start of my trip and the end of the trip. I did the ending shots exactly (well, within 1 minute!) of being 4 days (96 hours) or 3 days (72 hours). That way, when I figured “per day” vampire drain, it wasn’t really 2.7 days or 4.2 days. That way both tests were apples to apples as far as being whole multiple days.
Results With Dual Dashcams:
Starting Mileage: 212 miles (341.2 km)
Remaining Mileage after exactly 4 days: 184 miles (296.1 km)
Avg “Vampire Drain” per day = 7 miles per day (11.3 km/day)
Results Without Dual Dashcams:
Starting Mileage: 213 miles (344.4 km)
Remaining Mileage after exactly 3 days: 201 miles (323.5 km)
Avg “Vampire Drain” per day = 4 miles per day (6.4 km/day)
So the answer (at least in my case/car) is that dual dash cams on 24x7 increase vampire drain by 75% or about an extra 3 miles / 4.8 km a day above and beyond what the car itself drains.
In my case, in a garage and (except for these tests) usually plugged in over night, the relative miles are negligible. But if a car were to be left at an airport for a long time (especially in the cold), this increase in vampire drain could be very significant.
