SUPRKAR
Very early VIN Model S had metallic 'fun house' mirror. Later builds (certainly by early 2013--like mine) had glass mirrors).
Tesla service will replace them with real glass mirrors. At least they did for me.
You probably have the engineering/ design issues figured out, but I would note that whatever spring loaded SPST switch you choose to use must have a long throw to accommodate any variability in the depth of the cover, mounting of the mirror, thickness of the double stick tape on the back, etc. Better that the 'button' sticks out a lot when open, then be too short to securely and repeatedly disconnect power.
Tapping any aspect of the 12v system would involve running wires from the headliner thru the visor hinge and thru the visor body with a hole drilled in the current mirror.......unlikely it is a DIY job and would entail install cost and owner concerns about rattles, etc. ideally, our solution will install in minutes and battery operated for a feature that is used infrequently for short amounts of time will be practical. The batteries are cheap when bought in bulk....open to further ideas if a 12v solution could be done.....
It's been about 4 months. Is this project DOA?
FWIW, I had my S85 in last week for a routine 24k service. I requested an upgrade to the newer (still unlighted) slightly larger visors, which was done. They do help a bit, but note that they do not sit as flat as the old ones as the headliner was designed for the old smaller ones and not the current production versions.
And yes, artsci, still very interested in your aftermarket lighting solution.
I'm just going by what the Ranger said. He said it is stuck down on the headliner, just aft of the opening. I will look at some point, but not likely for several weeks at least.Count me in on this too. Lack of lighted vanity mirrors will be a deal breaker for my wife but as long as I can guarantee her something is coming soon, she'll accept it.
Is there really wire there that is unused that was intended for lighted vanity mirror when they eventually come out with them....if they ever do at this point?
are new headliners different to go with the new visors?
hello,FYI-I have sent the Tesla visor/mirror to Hong Kong for prototype development. We are also looking at alternative battery sizes to keep size and weight minimal. We want the design of the visor mirror to be c/w the beautiful look and design of the car....
