That makes more sense. For that square setup, you'd recommend 19x8.5 or 19x19.5 all around with the 255/35/19 tires?
are this the same rims as in this pic?
I'd suggest 19x9.5 with 265 tires if you want to get real aggressive, or 255 (still on 9.5" width wheel). Definitely stay square on this car!
Hey, that's me Yes those are V710FF wheels. 19x9.5"+33 on a Performance car with 265/35/R19 RE71R tires. Also keep in mind that this car is lowered about an inch with Unplugged coilovers.
do the wheels with fit without any adjustment to the car?
does the wheel and tire go past the front fender? I was curious about this for the 19x9.5 wheels on the front. I would prefer them to be flush. Is there much gain of going square 19x9.5 versus square 19x8.5?
How much range loss would you say? Maybe being flush might be worth it.
Looks great! Are you lowered in springs or coilovers?
I have a stealth performance so that should be the same as a non p car i think? these would sick out 5mm more than stock? I think i could live with that.Mine are +33 and it ends up being perfect on the P3D+ since stock is +35 (non-P cars are +40). I believe they also make a +35 in the 8.5" size and that would probably fit non-Performance cars but i haven't looked at one of those online calculator to confirm/check the poke.
Best bet is to order direct through them, they are very easy to work with and can mount/balance tires and ship to you. They're also in SoCal so you can do pick-up as well.
VMR Website
If I had to do it again I’d get square and go with 255 width all around, now that we know that size fits. On the performance I’d do staggered with 255 front and 275 rear.
