I am buying a second EV so I wanted another EVSE. I chose the Tesla Wall Connector because of the changeover to NACS standard and because I am interested in buying a Tesla. Future proofing if you will.
My experience with the Gen 3 Wall Connector and a Chevy Volt is it will charge it with a proper adapter (Lectron or Tesla Tap) but forces the Volt to charge immediately requiring me to get out to plug in the car and then get back in the car and set it back to charge for departure time. A real pita. I hope Tesla fixes this. Also, it is slow in negotiating with the car, it takes like 30 seconds for charging to begin. I have done several experiments comparing it to the old EVSE without moving the car so location has nothing to do with it. The old EVSE works as expected. The level 2 mobile charge that I have works as expected and the Wall Connector forces charge immediate override of departure time delayed charging.
Immediate charging would be expected when plugging into a Wall Connector at a Motel and I suppose that's why it works this way. Also, no one would buy a Wall Connector for a non-Tesla car before this new change over to NACS standard. It is inconvenient for me as a home charge as I plan to have a mix of car makes around. I'll try it on a later model and will replace it and return it if it still forces charge immediate override of departure time charging.
Also, beware of the NACS to J1772 adapters. The first one I bought would not charge the car at all and I had to return it and bought the Lectron adapter. Another point is it appears that adapters to go from J1772 to NACS are less expensive than doing it the other way around.
