No. (See below.)
That's incorrect.
Here is what the manual has to say:
Automatic Emergency Braking does not apply the brakes, or stops applying the brakes, in situations where you are taking action to avoid a potential collision. For example:
• You turn the steering wheel sharply.
• You press the accelerator pedal.
• You press and release the brake pedal.
• A vehicle, motorcycle, bicycle, or pedestrian, is no longer detected ahead.
Note the "Press and release the brake pedal." So clearly simply pressing the brake pedal is a different situation, and one that does not cause AEB to not apply the brakes or to stop applying the brakes.
Thank you for pointing out relevant wording from the Manual.
I have to say, though, that I interpret it differently. The quote essentially says that AEB does not take any action (whether initiating or cancelling the process of automatic braking) in situations where driver is taking action to avoid a potential collision. The list given in the Manual is labeled "for example" which means that it is not exhaustive; so the fact that applying the brake as opposed to applying and releasing it is not listed as an example does not mean that it is not considered an indication of driver taking action to avoid collision.
So to answer my own question, it appears that application of brakes by the driver *before* EAB initiated would indeed prevent it's initiation, but if sequence of events was such that EAB initiated *first*, applying brake by the driver after that will not cause EAB to stop applying the brakes.
