Glamisduner
I fully agree, I use it on my volt DAILY.Conplete opposite opinion on this. Been using the same kW Output measure on my Spark EV for over 3 years now and its saved me more than 1 time (including once when the rear electeonic brakes got semi stuck on).
It enabled me to easily gauge uphill and downhill terrain when I couldnt visually see the slope myself simoly by understanding my vehicles steady state power requirements and relative speed. Adjusting my driving patterns accordingly when I need or want to hypermile.
Super useful information to have that simply needs an option to be able to turn on.
Another thing I like to do is pop into neutral to accelerate downhill (when safe to do so) on longer stretches of the freeway. Much more efficient to just roll than using regen to charge back the battery and maintain speed. Guessing I can't do this easily on the 3.
I also like to swap between high and low regen, low regen is a more relaxing experience on the freeway, unless you know your going to need to stop up ahead, where I just pop the volt into low mode to help save my brakes add add back range.
I find I drive less efficient on the freeway with the volt in high regen mode, because to get best efficiency you don't want heavy regen to happen every time you back off the throttle a little. Grated tesla handles this a bit smoother than the volt in low regen mode.
