Concerns about consumption and range. Can anyone help me analyse these figures please?
I recently did a trip with the family :
- Model Y Long Range
- 100% charged
- outside temperature 12°C
- Family : 2 adults and 2 smaller children
- 186 km one way. We had something small to eat nearby and drove 385 km there and back (incl stops Supercharger).
- Mainly motorway. Fines are high here, I drive at the max permitted speed of 120 km/h (cruise control).
- During the outward journey we used the Supercharger and charged 80 km (the number of kWh is not mentioned, this is part of the free 150 km).
- The car indicated that we would not get home without recharging. So on the way back, we recharged
- the remaining 70km of the free 150 km AND
- 34 kWh.
- We arrived home with a battery charge of 43%.
I was told to take about 80-75% of the indicator as range. So 533 x 75% = 400 km. I had hoped that I would be able to cover less than 400 km on a full (100%) charge without any problem.
How should I interpret these figures?
- Fully charged : 533 km x 75% = 400 km
- Supercharged : 80 km + 70 km + 34 kWh.
- Tesla claims an average consumption of 17 kWh over 100 km. So that 34 kWh adds up to 200 km.
With the above, I then think I can do 400 + 80 + 70 + 200 (= 750km).
How am I wrong? Can someone please help me on my way?
It's hard to be very clear for range and consumption when you try to mix displayed range and kWh charged - amongst other possible errors such as capacity and phantom drain etc there are a lot of rounding errors which can make your calculation inaccurate.
You might be better approaching your calculation from a different perspective as I illustrate below. This approach can then be used to estimate your car's range under different circumstances and consumption rates.
For the purpose of my calculation I assume your car has the 78.1 kWh LG M50 battery. with an EPA constant of around 140 Wh/km? (Right or wrong?)
Using first principles and based on what you say in your post doesn't for me give a sensible answer (see my original calculation below the *****). The estimation for consumption is 253Wh/km which seems quite high (comparing it to my M3LR which I agree is not the same).
Did I understand your calculation correctly? Could it be that the total kWh you added is 34 (and not 150km+34 kWh)? If the calculation is done that way the result appears as below -
with a 34 kWh charge you would have had about the following available, 74.5+34=108.5
- battery level on return home, 0.43 x 74.5= 32 kWh.
- so in this case you actually used 108.5 - 32=76.5 kWh.
- with that consumption your Wh/km would have been (76.5/385) x1000 = 198 Wh/km.
That value would fit better, at least for me
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I could be totally wrong. Anyway the aim is only to illustrate an alternative for how to approach the calculation. There are also better battery wizards on the forum who could help you here (
@AAKEE and
@AlanSubie4Life).
Original first principles calculation based on what you said:
Fully charged = (0.955 x 78.1 kWh)= 74.5 kWh @ 100% displayed charge (ie full capacity of 78.1 - 3.5 kWh bottom end buffer of 4.5%).
You added:
- 150 km displayed = ~21 kWh (150 x 0.140 Wh/km), and,
- 34 kWh
So you started with 74.5 and during your trip added 55 kWh (21+34) = 129.5 kWh total kWh available (other losses not accounted for)
You ended your trip with 43% battery = 0.43 x 74.5= 32 kWh available.
You therefore used 129.5 - 32 = 97.5 kWh.
Your trip was 385 km which corresponds to (97.5/385) x 1000 = 253 Wh/km.
