What are the must have things for "Camping Mode" in Model S
Discussion in 'Model S' started by C_A_Braun, Jul 23, 2017.
Tags:
  1. C_A_Braun
    C_A_Braun Meet "Voodoo", Our S75 & "Solo Cup", Our Model 3
    So Cal / So Nev
    There are a few threads here about camping in the Model S but mostly about charging at camp grounds etc. Though a quick search also comes up with a few posts about needing an air mattress if you are actually going to sleep in the "trunk" I was hoping to get some personal experiences from those of you that have invested a little money into the "Camping Mode" option.
    What are the must have things to really pull it off with at least a little comfort (as opposed to sleeping on the ground outside the car)?
    Mattresses (What size)?
    Pillows?
    Blankets (or just use climate controls)? What is best for windows (blocking light as well as heat/cold if possible)?
    Tips and tricks?
    We did try it once at the Groveland CA supercharger a couple months ago, but we hadn't planned on it so we didn't have anythiing to help with the comfort level, particularly regarding the bump where the rear seats fold down.
  2. supratachophobia
    supratachophobia Active Member
    Columbus, Ohio
    You need that tent that attaches to the hatch with airlock. And you need a custom TT-30 to 14-30 adapter to bring along with your 14-50.
  3. kirkbauer
    kirkbauer Member
    Atlanta, GA
    I could use some advice on how to fully turn off the car and headlights without actually leaving the car with the key. In the past I have tried to park at night but stay in the car without drawing attention and it has been tricky.
  4. hpartsch
    hpartsch Member
    wa
    I'm still waiting for an official "camper mode" update. This was due months ago and was to alleviate the issues your describing. I too wonder what is the best mattress for this camping.
  5. BerTX
    BerTX Active Member
    Texas/Washington
    We have one of the tents that attach to the car hatch. It works well, although we are still working out the bugs. Well, not actual, physical bugs -- it seals pretty well.
    None of the apps with camper mode can work with the hatch open. In fact, even the Tesla app won't turn on the climate control with the hatch open. In reality, these are not really good solutions anyway, as they require data service of some kind, and that is often not available in areas where one might camp.
    Using the traditional camper mode turns on the DRLs, which is not appreciated by campers. And of course you can't be plugged in to use it.
    I have played with other solutions to keep the car on while charging that seem to work in the garage, but until I use them while camping, I'm not confident in them. It has been great sleeping temperature without any climate control the two times we have used the tent!
  6. kirkbauer
    kirkbauer Member
    Atlanta, GA
    I forgot to mention the other issue; as far as I know there is no way to secure your car as long as a key is inside, is there? Somebody can always push the driver's handle to get the handles to pop out.
  7. C_A_Braun
    So Cal / So Nev
    Although I must admit that I have not tried it, it would seem pretty silly if someone were able to push the handle and the door open if the keys were inside. Seems it would make you a prime target for a carjacking at a red light or stop sign. I know my camry doors wont open from the outside just because the key fob is on the inside.
  8. C_A_Braun
    So Cal / So Nev
    Will a "full" size mattress fit in the back? I am thinking at least a "full" super thick mattress pad, even if we have to curl the edges up the side a little bit.
  9. BerTX
    BerTX Active Member
    Texas/Washington
    a twin fits between the wheel wells. A full will not but as you say, it can curl up. To me, this actually gives less room since the thickness of the curled foam takes away from the width, but if it helps you...
  10. BerTX
    BerTX Active Member
    Texas/Washington
    Locking the car from the inside (with the screen) locks the door even with the fob inside.
  11. bhzmark
    bhzmark Supporting Member
    Can anyone describe how you can:
    1. Keep the climate control running with all lights off and all doors closed.
    2. Keep the climate control running with all lights off but the hatch open.
    3. Do either of the above while also plugged in and charging.
  12. smilepak
    smilepak Active Member
    Eastvale, CA
    A button on the screen saying" Camping Mode
    That let u run ac and leave lock doors
  13. Silverstreak
    Silverstreak Member
    Indiana
    There are you tube vids on this. Take a look.
  14. Skysurfer
    Skysurfer Member
    Iowa
    You can put the car in neutral, then go to E-Brake & Power Off and set the parking brake. That will disable the on screen front/trunk buttons but you can still open them with the keyfob. Final you can turn off the headlights and DRLs from the controls screen in US cars, other countries are out of luck on that one unless range mode would switch them off.
  15. supratachophobia
    Columbus, Ohio
    Dashboard for Tesla
  16. BluestarE3
    BluestarE3 Active Member
    Norcal
    For a Tesla Model S, shouldn't that be called "Glamping mode"? :)
    • Funny x 3
  17. BerTX
    BerTX Active Member
    Texas/Washington
    Dashboard for Tesla app can do #1 and #3 IF you have cell data service or wifi. #2 will not work -- the API won't let it for any app. You can't even turn on climate control with the Tesla app with the hatch open.
    All 3 requests require keeping the car on and active. I can't remember the exact method, but I'll test it tomorrow and get back to you. I don't want to give incorrect info.
    • Helpful x 2
  18. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    Doesn't RemoteS do this in the deeper menus? I haven't had the optty to use it, but I thought it did. Fortunately, camping mode uses so little of the battery that you don't need to be plugged in. Check out Bjorn's vids. he has figured all of this out.
  19. jkennebeck
    jkennebeck Member
    Richmond, VA
    Dashboard for Tesla will not work for camping with a tent attached for A/C in the tent. Fails after the first 30 min cycle.
  20. supratachophobia
    Columbus, Ohio
    Did you let the developer know? Not sure if this is fixable or not. But good feedback regardless.
    Edit: There is a way to fix this, I'll PM you.
