whitex
Correcting Gross Weight => Curb Weight - thanks ItsNotAboutTheMoney for pointing out the issue.
The issue is much simpler than people think, it boils down to power to weight ratio. My P85D curb weight is 4,936lb, add a driver and you're over 5000lb. Transmission doesn't add ANY power, it actually subtracts due to inefficiencies, so unless the electric motor somehow delivers less power at the high rpm, there is no need for one except to push the car to higher speeds that the max motor rpm allows. So why other cars with less hp can be faster, they are lighter.
So to answer the OP's original question, there are only 2 ways:
1. Subtract weight
2. Add more power - currently the power is limited by the battery
That said, this is a family sedan folks, over 5000lb of weight. It accelerates really well in its class. I think the perception issue is due to the fact that it basically blows most other cars out of the water 0-40, hence people expect the same at higher speeds. Unfortunately the 0-40 advantage is due to ICE inability to develop max power at low rpm, while the electric motor hp being mostly independent of the rpm. Once the car is rolling, the ICE engines can be kept at optimal RPM's (via a transmission) and then if they have a better power to weight ratio, they accelerate faster (assuming similar aerodynamic drag). Can't beat the laws of physics.
1. Subtract weight
