Ok for a camper. So you pull in get out, block the trailer wheels, raise the tongue jack, disconnect the WD, raise the jack more, disconnect the ball and electrical, (level the trailer if your fridge is running). Then charge the truck. Then you do have the camper to hang out in for ~45 min. Then do the first process backwards. You are looking at a minimum 30min extra and probably closer to 45 min.
Now do that 2-3x a day sometimes….
Yep, definite mind shift from doing Michigan to Florida in under 24 hours of driving (one sleep cycle).
Iakso[also] need to reset my mind to a relaxed journey vs cannonballing to destination.
Of course, stops can be less often with the range extender and lower travel speeds. I'll be interested to see if the air suspension can assist with trailer mating cycles. There is the also added benefit of taking the truck to any local less maneuverable spots.
Once at the destination in the wilderness, plug the trailer into Cybertruck and have all your amenities without a generator running.
