Leeclanual
The manufacturer (Tesla) does not recommend to charge to 90% specifically.
The slider is 50-90% and 90% is the maximum “daily” charge.
There is no Tesla recommendation to better charge to 90% than 80%.
Tesla does not use the recommendation to minimize degradation. Its most certain a combo of acceptable degradation and having a useble range.
Lowest degradation will be at low SOC, but if Tesla did recommend that we should charge to 50% or even lower they probably would get sued for selling a 300mile car that only can be driven 150miles, or less.
80-90% SOC during a lot of time will degrade the battery noticeble. 80-90% is causing about the same calendar aging as 100% SOC.
The car will (most probably) stay inside the >70% capacity after eight years anyway.
Calendar aging lessens with time and is quite small after about five years.
So using 80-90% SOC is not a problem condidering the warranty etc.
But if someone is worried about degradation, 80-90% will not cause the lowest degradation possible.
Using as low SOC as possible and charging often, preferably just before the car is to be driven could cut the degradation in half.
This means having 5% instead of 10% or 10% instead of 20% after some years.
For some it doesnt matter, for some the lesser loss of range is important.
Others can not charge at home and do not have the possibility to use low SOC or charge just before the drive. In this case, we need to accept the degradation as a normal sequence of the charging habits.
So I pickup my new MS on Tuesday… what % should I use? How often (%, daily, etc) should I plug it in during a normal week? I don’t regularly do long daily trips or road trips… generally a daily driver within 30-40 miles from home (golf, shop, restaurants). Thoughts to keep this battery healthy? I just sold my M3 after 4 years… charged it to 85% a couple times a week… charged it to 95% when going on a road trip. Rarely used SCs and my range over the years dropped from 307 to 290.
