Note: This feature currently requires accessing the site using the built-in Safari browser.
Hello,
Where can I purchase Tesla Model 3 Tire pressure sensors for 19" sport wheels? I don't see TPMS available in the Tesla website. Any idea how much it is?
Thanks in advance.
Thanks, any idea Tesla selling TPMS?
What brand it is and what's different from Tirerack or Tesla?
I have OEM tires and 19" wheels. I'm seeing 3-4 pounds of difference between the car's display and a pressure gauge. (gauge being higher tested with two different gauges). Also, I have had one summer/winter tire swap. Has anyone seen this or have a recommendation? Thank you!
I apologize for being a dunce but I still do not get this.Your elevation in Salt Lake City is causing this. The TPMS sensors are calibrated/referenced to sea-level pressure, not differential/atmospheric pressure like a manual pressure gauge. Elevation causes approximately 1 psi higher measured gauge pressure in the tire for every 2000' of height above sea level. Example: At 6000 feet, a gauge will read 3 psi higher than TPMS. The true pressure in the tire is the gauge pressure, not the TPMS reading.
The proper method to set your tire pressure at altitude is as follows:
1. Pick a pressure to run your tires at. The placard pressure on the driver's door jam is a good start, normally 42 psi for most Model 3's. You can run the tires slightly less (40 psi) for a more comfortable ride, or slightly more (45 psi) for longer range.
2. Set the tire pressure using a manual pressure gauge. This will fill the tires properly.
3. The TPMS readings in the car will now show a lower pressure (1 psi for every 2000' of altitude). Perform the "TPMS Learn New Pressures" procedure (Controls > Service > Reset TPMS Sensors > Learn new Pressures). This will tell the car that the current TPMS readings are now your "normal" pressures. This will silence any alarms from the TPMS system unless the tires actually get low.
4. This will not affect the TPMS readings -- they will still show lower pressure than the gauge. Keep that in mind when monitoring your tire pressures.
What is the TPMS sensor measuring ?
