At what Wh/mi?My 2013 classic 60 with 38,000 miles gets 200 on a range charge almost 6 years later.
The usable kWh’s is the issue
1) the EPA determines the rated range, not Tesla.
2) you seem to have just made up this 300wh/mi “rated average”. Where are you manifesting this number from? Why would it be the same for both the 60 and 85 when the 85 is significantly heavier?
Bottom line, you’re chasing your tail.
If you actually own a MS or MX you would know that the “Rated Miles” is a factor of 300Wh/mi. This is a given factor in the Trip Range Screen (sadly not available on M3).
No, they didn't guarantee, or even state, a usable kWh.
For example in the Audi e-tron they state it has a 95kWh pack, but only about 83 kWh of it is usable. (In addition to the anti-brick buffer on the bottom they have a large buffer at the top so that they can charge to "100%" faster.)
The usable kWh’s is the issue NOT the range.
I’ve owned a model S for 2 years now and have driven it 70,000 miles. Your claim is false. WH/mi to calculate EPA rated range varies with each individual configuration based on weight and performance. This is why a 100D and P100D have different rated ranges despite identical batteries.
You’re just wrong here. I’m not sure how else to put it.
This has turned into a clickbait if Fan Boys disputing any truth supporting a Claim against Tesla. -would be nice if real Tesla owners only could chime in.Sorry, didn’t want to read all the pages.. did anyone offer to join OP or is this a class of one and just a cute clickbait title for a “does anyone else have this issue?” Thread?
Can you point me to any documentation where Tesla guarantees a certain capacity of the installed battery will be available for propulsion?
(Hint: the answer is no)
Tesla installed a ~61kwh battery in your car and marketed it as a “60”. Your discontent with this is based on incorrect information and false assumptions.
No you are mistaken the 300Wh line is below the AVG 441 lineIf you zoom in you can clearly see that the rated line is below the 300 line.
No they did not install a ~61 This has been confirmed by the reports and documented by SVC. Hence they lye
You certainly don't have to believe it, but if you're gonna puff yourself up about legal claims and damages, it would benefit you to base those claims in fact. Repeating "lyes" will get you nowhere.
- Original 60 – ~61 kWh total capacity, ~58.5 kWh usable.
Tesla’s hacked Battery Management System exposes the real usable capacity of its battery packs
There is no 295Look closer. You will see the light 300 line just a couple pixels above the rated line. The scale is very compressed so there isn't much difference between 295 and 300...
Did I get a thumbs down because Fan Boys do NOT want real owners only to chime in -LOLThis has turned into a clickbait if Fan Boys disputing any truth supporting a Claim against Tesla. -would be nice if real Tesla owners only could chime in.
Not at all. I just think facts matter and find it important to correct misinformation for the sake of others reading this.You are awfully defensive ...
Further evidence your “rated 300” claim is not based in reality.58kWh won’t yield 208 at the Rated 300
