You have to monitor your tire's wear because vehicle placard pressure is just a starting point. Then adjust based on your driving conditions conditions. Just bear in mind that the air pressure is your number one defense against pothole damage.I was beginning to have excessive center wear at 50 psi. Tesla looked at it and agreed and lowered the pressure back down to 45 psi.
Do you sit on a pillow?For the record, I usually keep mine in the low 50s. Tire sensors go off at 57, fyi.
I can't tell much difference in the ride. I can tell the difference in tire wear and Wh/mi. Ride comfort is highly subjective.Do you sit on a pillow?![]()
I've tried as low as 37ps and as high as 50psi to try to help with rough ride. At 37psi, the car felt too springy/bouncy. It was unsettling and felt like I was in a boat bobbing down the road. At 50psi I couldn't tell much of a difference compared to 45psi. I ended up just leaving it at 45psi, preferring the rough ride over the bouncy ride.Interesting. I tested it today before I read your post and noticed exactly that. At 35psi I didn't feel any harsh bumps, but some roads gave a bouncy, overly springy feel. This was especially true at higher speeds (45-75mph).
My wife mentioned the same thing without my input.
IMHO in your part of the world 42 is too low of a PSII tried it for one day at 35psi. Too springy for me as well. Moved back up to 42psi already. First long trip tomorrow. Will see how it goes.
Interesting. Parked in the garage my right scroll wheel does not display 'Status' as an option. Any idea why that would be?Yours are a "thinner" lower profile tire so basically less air is required. No, the sticker is for your own rim/tire setup. Periodically I switch the right scroll wheel to display "Car Status" which is the PSI pressure of all four of the tires. When they lose a pound or so I use a nice digital pressure guage that I found on Amazon.com and this to fine tune it.
Tesla — Tire Repair Kit
Press down, hold and scroll to change to that display option.Interesting. Parked in the garage my right scroll wheel does not display 'Status' as an option. Any idea why that would be?
you need to scroll to the little picture of the tire to bring that info upInteresting. Parked in the garage my right scroll wheel does not display 'Status' as an option. Any idea why that would be?
Got it, thanks. The display doesn't fill in any values for tire pressure. Maybe it takes a bit.Press down, hold and scroll to change to that display option.
All tire pressure recommendations are based on a set of assumptions. The basic four are:
1. The ambient temperature is 18C (65F). If it's higher than that you need to adjust the pressure upwards.
2. Speed. The GY chart (and all other charts from the tire manufacturers (as far as I know) are based on a 65 mph sustained speed. If you run faster than that, then you need to up the pressures.
3. Load. For cars the load that the pressure recommendations are set at are for what the engineer thinks is going to be normal for that car--not necessarily the GVW.
4. A daily pressure check at the start of each driving day. (Don't shoot the messenger.) If you don't check every day, then you need to adjust the pressures upwards so that you never go below. Note that track use--where you adjust the pressures to get the most contact area is a whole 'nuther subject, and basically not applicable to normal driving (unless you like buying tires frequently).
For what it's worth, the door jamb placard on my March 2015 build Model S with 19" Michelins calls for 50 psi.
It looks like Tesla recommended 50 for a while, then went back to 45 psi.
When Tesla did the annual service on my car, they went to the trouble to reduce my tire pressure from 50 to 45.
I will set them back to 50.
GSP
Not funny. That's not what jerry said. Misinformation is the 34-35 BS out there and the discount tire idiots, not the door stickers.the door sticker is misinformation? could it be the russians hacking?
I had heard that the pressure sensors had to pass by a receiver. When the car isn't moving, it doesn't read.Got it, thanks. The display doesn't fill in any values for tire pressure. Maybe it takes a bit.
