SammichLover
Banned
I'm pretty sure those words had a very specific meaning, "FOMO! FOMO! FOMO!"Your sales guy is a sales guy and therefore their words mean nothing.
Given that V3 is specific for FSD features, nothing you said makes sense. Especially considering software for V2 cars won't know how to use V3 hardware.
... in exactly the same way my existing software stack does not know how to use the extra CPU cores and speed every time I buy a new Mac.
It's offered offline, but the reason they are downplaying it is that they are battery constrained and the RWD version uses a lot of batteries, but doesn't add extra profit the way the AWD version does. If they weren't battery constrained, it would be offered.I’m trying to figure out what the point of Tesla ditching the Model 3 with the longest range is. If the end goal is to let owners use their cars in a ride sharing service, wouldn’t the car with longest range be preferable in that scenario?
It's actually nothing like that.
On your mac you're just getting a faster version of the same basic architecture. The software can use the extra speed (it MAYBE can use the extra cores, depending on how multi-core aware it is but that's getting into the weeds).
HW3 is a completely different architecture than HW2.x
So when it's running the 2.x NN it's running in emulation mode. Which is a huge performance hit compared to running native code- and means it's pretending to be the original HW rather than having direct native access to the newer/faster HW.
Which is why Elon mentioned HW3 cars are actually slightly worse than native 2.5 cars right now.
It's a bit like when Mac first switched from PowerPC to Intel chips- even though the new chips were more powerful, the performance jump didn't exist for a lot of old software since it was largely running emulated on the new chip- and only as more things were re-done native to the new HW did the speed jumps really show themselves.
In this case it appears that advanced summon will be coming in the 2.5 code, and since that's the last feature ever promised for EAP, that's likely end of life for the 2.5 codebase, other than small tweaks/optimizations... though new HW3 cars can easily continue to run that in emulation.
Only folks who paid for FSD would need the HW3 codebase (that isn't out yet) and would thus benefit from the HW3 hardware.
Elon has stated multiple times only FSD will need HW3.
Which part, specifically, of my post do your years at Evil Medical School compel you to doubt?
The part where you assume that self driving is somehow different from Autopilot. The limit between them is purely marketing-driven. The hardware and software behind them are precisely the same, with FSD being nothing more than a functional superset of Autopilot.
This type of automation does essentially two things: it recognizes the surrounding environment (which, in Tesla’s case is mostly image processing) and then runs a decision-making algorithm (i.e. controls the steering, braking and acceleration) using the output of the environment recognition process as inputs. That’s all there is to it; it’s conceptually pretty simple but it’s computationally intensive.
Tesla’s most obvious problem is the fact that the outputs of the environment recognition module are largely *sugar*. Without better environment recognition, the decision-making algorithms can’t do much to improve the overall functionality (I take that back, they could choose to avoid charging into already-identified obstacles for example).
The above-mentioned environment recognition can be improved in one of two ways:
1. Throw computing power at it (which is what Tesla is doing) or
2. Use different/additional sensor suites that improve the quality and quantity of input data, without requiring extra computing power (such as using lidar for depth perception as opposed to determining it from differential image recognition)
Yeah, I don’t work for Tesla and I don’t know exactly what they’re building but, based on their observed functionality and progress I’m very much not impressed by the product in its current state and I believe their incremental improvements will be a lot less spectacular than people think they will be. And I bet that if they ever released their source code, a lot of AI experts would be shaking their heads ...
The problem domain size is a LOT different. With AP you are holding the lane, that's it. When you start deciding to change lanes, that's a massively larger problem. Thus requiring a lot more hardware to run your algorithms involved.The part where you assume that self driving is somehow different from Autopilot. The limit between them is purely marketing-driven. The hardware and software behind them are precisely the same, with FSD being nothing more than a functional superset of Autopilot.
Which outputs? What you the driver (and passengers) see on the screen?Tesla’s most obvious problem is the fact that the outputs of the environment recognition module are largely *sugar*.
Edit re #1 above:
Elon’s comment regarding HW2.5 running at 80% capacity vs HW3 running at 5% capacity tells you that they expect some 16x throughput for their current bottleneck, the image recognition algorithm.
I find it hard to imagine that a car with HW3 installed but FSD not purchased will never benefit down the road from software improvements. While FSD is their largest objective, a computer that is that much more powerful creates a lot of opportunity for improvement of other systems in the car, such as emergency braking and forward collision alerts.
When V2 came out nobody knew that Tesla would be coming out with Dashcam and Sentry down the road but would exclude V2 hardware from using it.
I don't see why we would think that will never happen again with HW3 once it becomes the main hardware platform. Are they really going to hold back development of non FSD related benefits just because there are some V2 and V2.5 cars still running out there?
Word on the street is that AP isn’t being bundled with the LR either, which makes a similarly configured AWD only $2000 more. Which lessens the appeal of the LR even more.
... given HW3 is running non-native code, that comparison is pretty worthless compared to what it can do with native code.
LOLI tried the newest Audi driver assistance package today, before I ordered my next car, and the adaptive cruise is way way better than that in Teslas.
LOL
It's time again Tee, get to bed and sleep off that 1/5 of bourbon.
“An absurd, bat guano assertion, probably dreamt up to just be contrary” is a special kind of “opinion” and thus receives a special kind of assessment.Oh, look, a statement I don’t agree with, let me give this guy a quick insult ...
Did this approach ever work well for you?
Yes, LR and SR are basically discontinued except they still have some HW2.5 LRs in stock and they want to sell those too. That's why LR is still available off-menu until they clear the stock. I don't think they will make any more LRs. SR is still available off-menu because Elon wants to feel like he kept his promise to offer a $35K version. They even went above and beyond and unbundled Autopilot just to keep it at $35K.
My guess is, LR is being discontinued because they will switch to AWD only. In other words, SR+ will be replaced by SR AWD. This will increase the price of the cheapest version which is a good idea for gross margins. In hindsight, they shouldn't have mentioned $35K at the reveal and neither SR nor SR+ should have been offered because the gross margins are either negative or close to zero. At the beginning of March, in my message here, I said SR would be discontinued. Now I think SR+ will be discontinued too and they will come up with SR AWD.
