That would be good, except the Owners Manual is blank for V9
May I suggest that you and the other 3 people you met at the SC read the owners manual. That's what it's there for.
I'm coming back to this one because it is a good point you make. Often I see people asking questions about things that are in the user manual. In this case the manual was of no help whatsoever. Thanks MasterT for showing page 61. I had read it earlier last week when I downloaded the latest manual and saw it on page 64. I always check the manual first when something changes.
My minor annoyance with the manual is that people writing it don't use proper descriptions, grammar, and sometimes misleading. They need someone with better English writing skills than me
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
This one is a good example. Example, the manual says "brake as you normally would". It's too ambiguous. It varies a lot between people. Something like "As you press the brake with a slight pressure while fully stopped..." would be less vague.
Further, unless I overlooked it in the manual, there was no description that one needs to press the brake much more firmly to activate vehicle hold when in creep on mode. Actually, creep mode is a bit misleading. There should be a description of the differences between creep on and creep off when pressing the brake. Ideally that would be in the "Brake" section and also refer to creep mode. I see other postings where people are confused that there is a difference.
Ok, so this is just one example. Folks also know there has been confusion in the past about needing a slight torque on the steering wheel to prevent nagging due to misleading terms in the manual and on the dash display. I'll bet you can point out other ambiguous statements as I have also seen in the manual.
Bottom line, I'm hopeful for better writers and reviewers in the future. Overall, I think it is a fairly good manual, yet needs tweaking and several new features aren't mentioned at all. The downside is that by the time they explain all of the details of upcoming full auto-pilot, that manual could be larger than the bible. I guess we can't win on this one. Fortunately, there are a lot of smart people here whom experiment and properly explain what the manual really means
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
As my English teacher used to say, "Communicate not only so you can be understood, but so you also CAN'T BE misunderstood."
