That's good to know, but what about battery pack heating? I thought that came on when the cabin heat was turned on. It would be nice if the car could do everything it can from shore power before you head out so that you don't "waste" battery power doing things that could have been handled from the mains.
I can confirm that when you start with a battery that has finished charging and no longer charging and the car is still plugged in and you start the cabin heating from the phone app, the heating in the cabin starts and the power seems to be coming from the wall (as the flashing green lights on the plug start to flash). This would indicate that the cabin heat is drawing current from the wall. Great. Logical. It is plugged in so why wouldn't it.
However, I do not know if the battery does start heating up when you start the cabin heating and if so, does the battery heating happen with wall power or battery power. As you said, would make so much more sense to use the wall power if you are plugged in!
Lastly, there is something someone is going to have to explain to me because I just cannot wrap my head around the following facts and example:
I plug my car is plugged in when I get home in the evening, charges up to full (shows 449 Km ideal range) by 10:40pm
I check it this morning (still plugged in) and it shows 436km (at 8:52am)
Check again at 9:48am and it is at 435km
Check again at 11am and it is at 433Km
So basically, when plugged in and at full charge it stops the charger and then begins to lose range to the tune of over 1.3km per hour in a 20 degree Celsius heated garage. Why????
Every other piece of electronics I own, including the Roadster, will hold the battery at full charge if it is still connected, even when it is at 100%. I understand there needs to be some hysteresis or threshold to start charging again after it loses some charge but shouldn't it do some kind of trickle charging so that it is always at max charge while connected to the wall? I do not get it. sorry if i have missed something here.
