bkp_duke
Which is it? Yes. Warm water holds less gas under static conditions... but we're increasing the concentration of CO2 in the atmosphere which is why even as the oceans warm they are absorb more CO2 increasing the acidity. I'm betting that NOAA has a trained chemist or two also.
It actually indicates that the ocean reached it's "buffering capacity" for CO2, or is approaching it. I.e. it soaked up all the CO2 it could. As temperatures rise, the cycle accelerates.
I'm not doubting NOAA - I'm doubting your ability to understand the details of the science. The impression I get from you is you're a "headlines" kinda guy, and that's about it. Sensationalism to make your point, but gloss over the words that are larger than 2 syllables.
In fact, just for you, I'll quote NOAA here (for the simpleton in the room):
http://oceanservice.noaa.gov/education/pd/climate/teachingclimate/acid_base_chemistry_teacher.pdf
"The oceans have the ability to “absorb” or buffer the additional acids entering the water as a result of increased CO2 in the atmosphere; however, if there is too much acid, the buffering systems become overwhelmed and the pH in the oceans begin to drop."
That last line is the key there chap, you don't get a free ride for ever, and once the "buffering" capacity is hit, atmospheric CO2 skyrockets (like in the last 2 years) because it no longer has anywhere in the water to be sequestered. That increased atmospheric CO2 further drives warming, which pulls MORE CO2 out of the ocean. Etc. Etc.
It's an intertwined cycle that once started tends to run out of control:
Burn Carbon Fuels --> Increase Atmos CO2 --> Absorbed by Ocean (helps slow the rate of rise in Atmos CO2) --> Lowers pH --> buffering capacity overwhelmed (I.e. ocean cannot absorb any further significant CO2) --> Atmos CO2 skyrockets --> warming accelerates --> Ocean temp rises --> accelerates the chemical reaction of HCO3- (the Atmos CO2 that was previously absorbed and converted to an ion) to CO2 gas --> further increases atmos CO2 --> further accelerates warming
