Several weeks back I also installed the 55W 4500K HID lights from ddmtuning to replace the low beams. Very impressive.
1) Using my ancient Sekonic light meter, output went from about 160 foot candles to about 640 foot candles at a distance of a few feet.
2) Light pattern is pretty good, cutoff remained intact
3) Did not need to loosen any screws, so did not need to re-aim.
4) I used a 7/8" Forstner bit in a drill press to drill the hold in the rubber grommet for the wires - came out cleanly.
5) Hardest thing is figuring out where to put the ballast and then mounting it. Note that ddmtuning also sells mounting plates now.
6) The 4500 K color temp is just slightly bluer than the stock high beams.
7) I do not recommend replacing the high beams due to the startup time of these HIDs. Unless you don't care about flashing the high beams. Doing the high beams does require some wire cutting/joining - the low beams are plug and play.
8) I don't understand MPT's thing about putting the wheel on the hub in the same place - it's not like the tire/wheel is balanced on the car or anything.
9) It is true that HIDs run cooler than the stock Halogens, as measured by the hand over the headlight housing test.
Bottom-line: for $35 plus shipping, this is a great upgrade for your Roadster. Put the money you save towards the extra sound installation kit!
