Don't have 50 amps available.
Sure you do. Coincidental loads rule. Charge at night, when you're not using your oven/dryer/etc.
Not as evil to make an adapter. Clearly mark it Tesla use only and keep it with your UMC.That was discussed in another thread I read but that most thought it was a big code issue. The fear being the outlet being used for a device that required the neutral at some point.
Post #15, talks about this. Basically leave the outlet alone, get the 14-30 adapter and wire a 10-30 plug -> 14-30 receptacle. Just link the neutral to ground in the plug to receptacle adapter.That was discussed in another thread I read but that most thought it was a big code issue. The fear being the outlet being used for a device that required the neutral at some point.
kSure you do. Coincidental loads rule. Charge at night, when you're not using your oven/dryer/etc.
Why not install a HWPC?Why did you pay someone to install something other than a 14-50????
Why spend another $550?Why not install a HWPC?
Fast home charging with surge protection without having to worry about adapters...Why spend another $550?
Alternating currents , well, alternate. One reason many devices have the little black transformer is to convert to “clean power” and extend device life. HWPC does this. I bought an electric car that I intend to have for a long time. I intend to have my house for a long time. My garage did not already have a 14-50 but, in any case, It made sense to me to have purpose built charging for it. I’m an engineer turned accountant and jury rigging would drive me nuts...Can’t help itYou don't have to worry about adapters with a 14-50. Works out of the box. Costs $9. Also I don't know that the HPWC has any surge protection in it, but even if it did, you'd want you $550 device to do that which could leave you chargeless, or spend a couple dollars on whole-house surge protection?
I have both. Because I can charge at 80A, and if it breaks I can use the 14-50. But I know the HPWC is a dumb luxury.
Uhhhhhh, no. I think you're thinking of the contactors. That's not what they do, and the UMC has them too. There's not much in that box. Surge suppression comes in the form of single-use varistors that would have to be replaced if hit hard enough. You should get whole-house surge suppression if you really care about your stuff.Alternating currents , well, alternate. One reason many devices have the little black transformer is to convert to “clean power” and extend device life. HWPC does this.
Mistake, I had a 10-30 elsewhere in the house and saw that it was supported by Tesla so I figured I'd swap things around. I should've done more research.Why would you even think to install a 10-30 when it is an old standard, replaced years ago by the 14-30?
Alternating currents , well, alternate. One reason many devices have the little black transformer is to convert to “clean power” and extend device life. HWPC does this. I bought an electric car that I intend to have for a long time. I intend to have my house for a long time. My garage did not already have a 14-50 but, in any case, It made sense to me to have purpose built charging for it. I’m an engineer turned accountant and jury rigging would drive me nuts...Can’t help it![]()
Thanks, I talked to the electrician and it seems they would have to charge me to crawl under the house again and redo the wiring...
I've contacted Tesla support and they said it's been discontinued. I just paid $600 to have the outlet installed and now don't know what I'm going to do.
Do you mind posting here when it becomes available?
