not so easy when you're 140 miles from the service centerApproval is pretty quick, even with the recording process.
I've offered my advice to you already, you are being BSed, make some noise of your own, go up the food chain at tesla and get your car repaired!
they haven't and AFAIK there really isn't anything coming soon. There is a possibility of continued usage causing a catastrophic failure, YMMV.Yeah, I know. It's just not bugging me enough to make a "special trip", and as I think I mentioned here or in one of the other DU threads, I was kinda hoping for some indication that Tesla had figured out a more permanent resolution to the problem.
The part number is the same as the older Drive units only the last letter is different that specify revision. And Q is the latest revision last time i looked in the part catalog.
But have been changes to rotor/stator in the latest revisions according to the part catalog.
and FWIW, i'm on my 4th DU and the milling noise is getting louder. so i'll need a 5th drive unit probably within the next few months (whenever it gets loud enough to annoy other people that's usually when I bring it in, lol).
I've stated this in numerous threads: Tesla's approach to the DU issue is to patch the problem; not engineer a solution.
I hope I'm wrong.
Again, I think AWD is there engineering solution. It either reduces strain on a single DU to the point it won't fail or it pushes the problem back until way later when you don't own the car anymore.
If your ICE engine noise doubled or tripled from new, you can bet it would get replaced.Some people get their DU replaced because they can hear it... how many IC engines would get replaced if that was the standard :wink:
Most DUs do not get replaced; Most that do get replaced due to noise... not 'failure'.
My question is this...if Tesla is having hard time with Drive Units with $70K + cars and they cannot seem to come up with a solution
How are they going to deal with mass release of Model 3 with cars around $40 K range and still deal with drive unit issues?
I am currently scheduled on Oct 30 to have technician record the noise on second drive unit.
Bummer![]()
That parts catalog screenshot listed several part numbers (not just revisions). Seems that many people were getting a 102xxx unit where M and newer were post-AP, but I got a 100xxx unit for my replacement back in February.
Edit: To be clear, I have a 1002633-01-M in my car now. Others are getting something like 1025276-00-K, and on that 1025276 part we know that M and later is AP. There's also 1056680 and 1025598, and 1056681.
Tesla is not sitting on its hands here. Look at the serial numbers that owners are posting. The drive units have undergone numerous revisions. The one I received in February was either a K or M revision, brand new from factory, and recently I've read of people getting P revisions.
...since we're still on V1 of the driveunit with Rev P...
I never said they were sitting on their hands. From my observations, since we're still on V1 of the driveunit with Rev P, they're patching problems. The engineered solution at this point (well, actually a while back), might be to start from scratch and have a DU V2 Rev A.
Pushing revisions is usually cheaper short term than starting from scratch. But at some point, when you're on Rev P (and sure, not all the rev's are due to problems, they're probably doing simulatenous improvements) and people are still having problems, it might be time...
I still hope I'm wrong, but that's what it looks like from the outside.
Why would they need to start from scratch? The battery packs are also being revised. We started with A packs and now have D and E and who knows. The fact that we've been able to document a number of revisions just in the last year speaks volumes to the fact that Tesla is making revisions to the drive units. There is no evidence that these revisions are "patches" versus engineered fixes. We have no way of knowing. But the DUs are evolving much in the same way as the batteries. You re-engineer something and give it a new revision number.
Battery packs don't keep failing.
Worth also mentioning here that I (and others) have been told that Tesla has been working on a Service Center based fix for this issue. My SC wanted me to wait until it was available so that they could effectively remanufacture my DU in situ, at least that was the implication. If that is done, then it won't be a true "DU replacement", but a repair. Obviously the hope is that it's more permanent, but if they're moving in this direction then it implies a lower cost overhead vs. DU replacements.
