android04
I read that it's JIS B24 size which is a Japanese size and pretty close to group 51.
The R means the positive terminal is on the right (which I assume is with the terminal side facing you).
That is correct for the orientation. The battery is RFP. I thought for some reason that R in the code meant reversed (from “standard”)
How do we know this is what the R means?
This is how we know: Group 51 and 51R Batteries - Dimensions, Features and Recommendations
I guess the document from the manufacturer is wrong. Could be wrong about the AGM too though the price suggests it is not AGM.
The linked AtlasBX document is the international one. Look at the US specific document for more information on the battery. In that one, it lists the battery as Group Size 51. I've been telling people that Group Size 51R is positioned exactly like the OEM battery, but if there's enough slack in the cables a Group Size 51 battery should work fine (the terminals are not centered on the battery and using the non-R would put them a few inches away from the original position).
Here's the info from the two Hankook AtlasBX documents. I also do not believe that the OEM battery is AGM because of the nomenclature in the documents.
US
International
