Schlermie
P4932 - Delivery: 12/22
Wanted to see if there was any updated info on tire wear out there.
I have one of the early models which showed extreme wear on the 21" tires. When I went in for the 6000 mile rotation, I had to completely replace the back tires due to extreme wear on the inside edges (and no wear at all on the outside edges). When I took the car into the service center at 12 months (~12000 miles), I asked them to make sure the toe was set to 0 on the rear wheels since the negative camber tends to chew through the inside edge of the tires. The service center added this item to the service list:
Customer concerned about rear inner tire wear. Bulletin: Model S | SB-13-31-004 | New Bolt for Rear Camber Correction
Correction: Replace Upper Link to Subframe Bolt
My rear tire wear has been much more reasonable ever since.
