bradjc
Actually I can't get a hold of 245's so it will be same as you and get the 255/40R20. I'll just have to keep in mind to avoid hard lock in reverse I guess. Looking forward to them!
A small update on the Michelin Pilot Super Sport 255/40R20 tires on the 20x9 T Sportline turbine wheels. I now have about 6,500 miles on these tires.
Pros:
Cons:
- Handling / traction / performance in dry conditions is awesome ... very grippy.
- Handling / traction / performance in wet conditions is also excellent, which is somewhat surprising for tire with a low amount of siping.
- Noise level is quite low, and rotations have kept it low.
That said, I would buy these again for a summer tire.
- Tread wear trend is showing that I will reach the legal tread wear limit at approximately 20,000 miles. Original tread depth was 7.9 mm, all 4 tires are now averaging about 5.9 mm @ 6,500 miles.
- High cost. There are other tires that are close to this tire's performance for less money.
- 255/40R20 does have a slight rub on the front wheel wells when going in reverse and steering wheel is turned more than 3/4 turn. Use 245/40R20 if this is bothersome.
- This tire increases energy usage about 10-15% over the Michelin Primacy MXM4 in dry conditions.
- This tire is heavily affected in energy usage by rain/wet conditions. In heavy rain, I'm averaging close to 400 Wh/mi at only 68 MPH.
Thanks for the update SomeJoe7777, I'm running the same setup as you, have done 1,000kms in a week only, but so far impressed. The margins are tight for me but don't get a rub in hard lock which I was expecting from your experience. Possibly a slight touch but I can't feel it.
Cool! I wonder if the front tire/wheel clearances are slightly larger for you either due to RWD (I'm AWD), or coil suspension (I'm on air).
I had a TPMS issue with my first set of TST wheels. I purchased the TPMS modules from Tesla but they sold me the wrong ones. My vehicle is newer and uses the Continental TPMS sensors, whereas they sold me the Baolong sensors for the older models.
They were able to tell which sensors were installed in the wheels using a scanning device they had. When they told me they were the wrong ones, they offered to replace them for me.
That's a great looking car! Wheels fit perfectly.Bumping this to first page to thank SomeJoe7777 for his leadership on this issue.
Here is my S with 20" TST's fitted with Michelin PSS 245's squared on coil suspension. Love the result.
Do you have to change anything in the car's programming or settings when you change tire/wheel sizes? I love the look of the 20"s BTW!
