tstafford
Slightly off topic but it's annoying how Tesla rolls out these updates. I'm still sitting on 2.7.56. Wish I could force an update like most firmware.
I think that update should do it for you, after some checking with the REST api, I have a logging app that runs 24/7. I can get some example pictures, but basically prio to 2.9.12 (but on 7.0) it was quite aggressively targeting the setpoint temperature. I had it set to 21.5C and thats what I was getting precisely. I was happy with that myself.
Now on 2.9.12, it does like on 6.2, it just reach target and overshoot largely, without correcting. Set 21C you get 23-24C after 15-20 min... I find it stupid, but its what people wants.
The next complaint will come when they'll add the actual cabin temperature on the display (and its probably why they don't). Set HVAC it to 21C, and showing the real inside temperature of 23C.
I think its mostly that we are used to that, and while driving in the cold we get colder and colder and need more and more heat to feel comfortable. Having to bump the set point to 21.5, then 22, then 23.5 and so on would be annoying.
So this update restore the original lazy temperature control: Set something, get more.
7.0 prior to 2.9.12, get what you set
6.2 & 7.0 with 2.9.12 (get whatever over what you set)
I think the reasoning for the temperature is that the sensor is in the centre of the vehicle...
That is quite likely, I would bet they didn't think to make 2 different HVAC algorithms depending on which sensor location you have. (though that's probably what's really needed)This might be part of my problem... maybe the HVAC was "tuned" for the newer sensor location???
Yes, it does seem strange. I had a bad flat tire and had to go in for a new one, and that's when I was notified of the update via the app. Is it because I was at the service center? Or was it a coincidence? I have no idea.Slightly off topic but it's annoying how Tesla rolls out these updates. I'm still sitting on 2.7.56. Wish I could force an update like most firmware.
I think I'm seeing something completely different. Prior to 7, I had to keep the temperature at 67 to make the car "feel" like 72 did in every other car I've owned. Okay... no big deal and I got used to it.
With 7, I found that I had to bump the temperature up to 72. It seems to get there just fine, but the car clearly is drifting down as I drive. My feet and legs get quite cold. Whereas 67 used to be "fine" before, now I have to start out at 72 and eventually bump it up to almost 80 over the course of a 1 hour trip.
It is annoying, but I'm not convinced that I just start to "feel" colder. It really seems to me like the interior actually is getting colder, but, of course, I have no actual measurements to verify that.
Looking forward to seeing how 2.9.12 works when I eventually get it.
It seems to me the real reason they can get this right is hardware - more sensors are needed in more locations. All the software tweaking in the world won't help.
If true (yay), I have mixed feelings. On the one hand, I want my heating back (2.9.12) but on the other hand I don't want my AutoSteer nerfed (2.9.40).I found that 7.0 heating prior to 2.9.12 was reasonable for the first 15 or 20 minutes but temperature became erratic after that; particularly on the highway. 2.9.12 seems to work perfectly - temp is stable again.
Having recently driven on a trip ranging from ~60°F to -4°F, the behavior in .77 is not "it's actually using the temperature you set rather than biasing higher."The next complaint will come when they'll add the actual cabin temperature on the display (and its probably why they don't). Set HVAC it to 21C, and showing the real inside temperature of 23C.
What it appears to be doing is trying to be conservative with energy spend in the cabin. When parked at a supercharger in 2°F weather, the CC was set at 72°F and I was toasty *in a tshirt*. When leaving the supercharger I put on some additional layers (long sleeve, jacket) and left the CC at the same 72°F. while the temperature outside rose to 10+°F, I was shivering inside the cabin within 10 minutes..
