Anyone that reduced brake rotor weight on all 4 wheels on here? Curious about range improvement, comfort and acceleration/deceleration.
Thanks, will go with lighter 12V first then.
Obviously, tires and wheels are the #1 as far as efficiency is concerned.
Lowering the car is probably your best "bang-for-the-buck" efficiency modification. There's a lot of spring options these days if you don't want to invest in coilovers.
Then, I would buy a performance style spoiler (assuming you don't already have one?); they're cheap.
Next, UP front lip.
Anything else is going to offer very little if any gain.
I agree, the ultimate combination for an efficient rotating assembly is...
1.) lightweight wheel, e.g. less than 18 lbs (for 18"), less weight, less power needed to turn the wheel
The lighter battery will do even less for range than the rotors will.
Lowering it might actually help a meaningful amount.
Tires and wheels aerodynamics are the other meaningful items though are good factory.
Beyond that you are going to be chasing your tail.
The fixation on wheel diameter and therefore weight around here is missguided as it is usually the tires that are making the difference.
Do have a list of these? I am interested in lightweight wheels. Everywhere I look, almost no one specifies the weight of the wheel.
Tirerack has some, looking for other options out there.
Ankle weight is the worst.
