Making this thread as part 2 to the saga of getting my model S to work. The drive unit is properly synced (Model S Rooted v11.0 2022.8.10.5 drive unit replacement problems), however now there are now battery issues. I was told there were no battery issues before the drive unit died by the previous owner (about 2 months ago), however I cannot verify this fact.
This current battery pack was put into the car around April of 2022 by Electrified Garage (I was told it was a "newer battery pack" but was never given the exact specs. the sticker by the passenger front well is pretty poorly degraded too).
Before fully fixing the drive unit, the code "BMS_w_107_SW_Cell_Voltage_Sensor" started to appear (from my records this code started to appear sometime in the last 3-4 weeks, and the car has not moved or driven at any point. It was towed and jacked up several times for replacing the drive). Now that the drive unit is fixed and synced, there are numerous BMS codes (see picture). I have also attached a picture of the current BMB Voltages. I have not checked for isolation issues, but the error messages don't suggest it. BMS_w155_SW_BMB_Vref_leaky and BMS_f097_HW_BMB_Under_Voltage and BMS_f098_HW_BMB_Over_Voltage also intermittently appear. I believe all the other codes are present because of the BMS problems.
From what I can tell, module 10 has a difference in voltage of .087v, and I am wondering if module 10 is the cause of all these current problems. The error messages seem to point to it, but I wanted to see if anyone had more information. Looks like the pack will need to be pulled, which I will do if needed. How practical will a module replacement be if I can CAC match and find one that is about the same age/part number? I know I will be told to just get a new/used pack by some on this forum, but that is not an option for me. I would rather part the vehicle out instead of spending 5-15k on a pack, simply because the car is not worth that much. Or, is there something else that I am missing, like a connector or wire?
The BMS Codes are:
BMS_f071_SW_SM_TransCon_Not_Met
BMS_ w164_SW_Brick_SOC_Imbalance
BMS_ w166_SW_AhToBeCharged_Imbal
BMS_4008_limpMode
BMS_W129 _SW_BMB_VSH_Connector
BMS_w107_SW_Cell_Voltage_Sensor
The BMS Codes are:
BMS_4008_limpMode
