2013 S 85 Charge Port Replacement Tips?
Discussion in 'Model S' started by teslick2, Sep 1, 2019.
  1. teslick2
    teslick2 Member
    Virgina
    Hi all,
    The charge port on my 2013 Model S 85 has a few issues and the service center said that the port and door should be replaced. Unfortunately they quoted ~$900 to do the work, whereas used charge ports and doors are about $75 on eBay. It doesn't look like a lot of work, and the port is held in by 4 screws.
    Before I dive into this thing, does anyone have experience changing the charge ports on an older Model S? Or any tips they could share?
    Thanks!
  2. Akikiki
    Akikiki A'-Lo-HA ! y'all
    Kaneohe, HI
    You are considering putting your body at risk to replace it where there's HV cables? Wow. I'm old and far from being as useful as I once was and I would NOT consider doing it myself.
    • Funny x 2
  3. teslick2
    teslick2 Member
    Virgina
    Isolating the HV and 12V are pretty simple. After that's done, my biggest risk is cutting my fingers on sharp sheet metal.
  4. Akikiki
    Kaneohe, HI
    Hey teslick2, I wish you well. Will you have your descendant drop into TMC and tell us which action it was that took you?
    • Funny x 4
    • Disagree x 1
  5. Saxgod
    Saxgod Thread Necromancer
    Texas
    A bit melodramatic don’t you think?
    Just because you aren’t capable doesn’t mean he isn’t. He came asking for how not whether he should.
  6. tj1772
    tj1772 Member
    Las Vegas
    There is a DIY video on this. I have to find it. It's straight forward. I remember you have to disconnect the battery and the access is behind the liner in the trunk.
  7. Akikiki
    Kaneohe, HI
    #7 Akikiki, Sep 2, 2019
    Sax, old buddy, :) I think teslick2 got the spirit and my meaning better than you did. Just like you assume that I'm not capable because I choose not to risk it.
  8. teslick2
    teslick2 Member
    Virgina
    Thanks! I look forward to seeing what you find.
  9. NoMoGas
    NoMoGas Supporting Member
    Los Angeles, California, United States
    Do it yourself. The HV cables arent even hot (check with meter). You'll need to remove your tail light.
  10. tj1772
    tj1772 Member
    Las Vegas
  11. tj1772
    tj1772 Member
    Las Vegas
    • Informative x 2
  12. ebogle19
    ebogle19 New Member
    ORLANDO
    I can only fing GEN 2 charge ports on ebay. Can I use the pins on the GEN 2 generation?
  13. ebogle19
    ebogle19 New Member
    ORLANDO
    I have a non-automatic charge port
  14. teslick2
    teslick2 Member
    Virgina
    Maybe. The pins must be the same shape so the charging cable fits in, but I’m not sure how the pins connect to the actual port on the gen 2.
  15. ebogle19
    ebogle19 New Member
    ORLANDO
    How can I find the GEN 1 port? I cannot find it. And thank you for the help
  16. teslick2
    teslick2 Member
    Virgina
  17. Vip
    Vip Member
    United States
    So I replaced the charge port on my 2013 Model S. After replacement the car gave 2 errors: Car needs service and car needs software update.
    Has anyone had this issue and if so what did you do to resolve this?
    Thanks
  18. Vip
    Vip Member
    United States
    So I had an interesting experience with the replacement.
    As stated before, after I installed the new charging port multiple errors appeared. I could not drive my car or charge it.
    One of the errors that appeared was that a software update was needed.
    Luckily for me I hadn't downloaded the latest OTA update and it was sitting there to be downloaded. (it never downloaded because it wasn't connected to wifi.
    I had the new port in and started downloading the update but the car totally crashed. It messed things up so much that I couldn't get the car started or working. None of the screens would work. At this point I seriously thought my eMMC failed!!!
    I changed the port back to the old one. The car started back up.
    So I decided to download the update with the old port installed.
    Once the download was complete I re-installed the new port. Then I completed the installation of the update.
    Success!!! After the update completed installation it recognized the charge port and everything was working great.
    FYI: I did call Tesla beforehand and they said I could try the current pending download. If that didn't work then I would have to go to the service center for the update. Which surprised me and think it is BS that they can't send the software update OTA.
  19. ucmndd
    ucmndd Well-Known Member
    Yes, you need to redeploy the firmware after the part change. One handy way to do that, as you discovered, is to have a software update staged. :)
  20. Akikiki
    Kaneohe, HI
    Wow. @Vip, You were lucky.
