Good comparison by Clean Technica of Model III vs. laundry list of other cars.
Tesla Model 3 vs 22 Competitors — The Straight Specs
New rotary-fuel-cellWhat the heck does Toyota get from partnering with Mazda?
Why? The X is based on the S that has normal doors and it has FWDs. So why couldn't a Y if it is based on the 3?
Elon said that their mistake with the X was introducing too much new technology in the first version of the car. Now that Tesla has finally figured out how to produce the FWD's with similar efficiency to the MS I believe that the decision will probably be based on wether Tesla believe that they can fully automate the production and if they believe it's a desirable feature on the Y.Production Hell for months
Quality Hell for months
Ongoing reengineering for months to get quality and ease of manufacture under control.
In the end Tesla said they ended up modifying 70% of the Model S platform. That is why Elon originally said a sedan platform should be designed for a sedan and an SUV platform should be designed for an SUV. [Rob, in this context how is this relevant?]
Originally one of the main raison d'être for the FWD is access to the third row. Model Y will have no 3rd row.
Now, in order to get Model Y to market as quickly as possible with good quality and easy ramp up maximum transfer is the order of the day. Meaning use as much of Model 3 in Model Y. FWD don't fit those marching orders.
And a graph for Q1 Addressable market.Good comparison by Clean Technica of Model III vs. laundry list of other cars.
Calm down. I trust Elon and Tesla that they know better than you do/we do here and that they allready know they they need more GFs...Can we just all agree that there is almost no reason left to buy any other car than the Model 3? This is as of today.
Model 3 is better in each category than nearly every car separately. So combined... I mean... Idk.
More than 10 MILLION people buy the cars listed in that article EACH YEAR.
How will Tesla meet that demand with one Gigafactory?!
We're not talking 2020 or later. Model 3 is better in every category than 95% of competition in each category NOW.
Could you help me find this info plz? I see on page 7 they have "recharge event energy" at 89.41 kWh and "charging depleting range" at 454.64 miles. If we use the advertised 310 miles, wouldn't this indicate 61 kWh of a single charge?1. The long range version appears to have an ~80kWh battery. This would explain why Tesla called it "Long Range" instead of by its number (80). They're obviously afraid of Osbourning the much more expensive Model S, which is selling with a 75kWh rated battery.
Yes. And Tesla notes at the bottom of page 6 & 7, also reference a 78.27kWh battery pack.Two things:
So it seems like Tesla would call that an 80 kWh battery pack.
- A full charge took 89.41 kWh from the wall. If you figure that the charger is 89% efficient it put 79.57 kWh of energy into the battery after being depleted.
- 351 average voltage times 222.81 Amp hours = 78.2 kWh
There may also be an argument FWDs help uniquely differentiate MX from MY reducing some of the similar angst of M3 v MS.Most people that can't afford an X but might buy a Y are afraid of the potential repair cost of FWD.
The number of potential customers that will buy something other than a Tesla if Model Y offers conventional doors seems rather tiny vs the potential lost customers if Tesla does use FWD on Model Y.
EPA testing documents for the Model 3 have appeared:
https://www3.epa.gov/otaq/datafiles/CSI-HTSLV00.0L13.PDF
There are at least two things of interest:
2. They appear to be using a permanent magnet AC motor. This would be a first for Tesla, and perhaps curious for such a high-volume vehicle as a PMAC motor is generally more expensive and supply-chain sensitive for it's rare earth metal components. However, they're generally more efficient than AC Induction motors, which might explain some of the range improvements.
Then what do these 450+ miles on a single charge really mean? Is this more aligned with "perfect condition" or something?Three things:
- A full charge took 89.41 kWh from the wall. If you figure that the charger is 89% efficient it put 79.57 kWh of energy into the battery after being depleted. (Edit: Since Tesla says the end SOC is 78.2 kWh that means that the charger is 87.5% efficient, so less efficient than I guessed.)
- In the manufacturer test comments: END-SOC - 78270 wh. = 78.2 kWh.
I think you are missing what the actual tests show:
- The Model 3 Long Range went 495.11 miles on a single charge. (Using the 81 - Charge Depleting UDDS: SAE J1634 Multi-cycle test procedure.
- The Model 3 Long Range went 454.64 miles on a single charge. (Using the 84 - Charge Depleting Highway: SAE J1634 Multi-cycle test procedure.
We also learn that it's "engine" is "normally aspirated" and that the battery is 221.81Ah with average voltage of 351V for total energy of 77.86kWh. This is in conflict with information from Senior Tinkerer wk057 who stated confidently that the battery is 402V with 96 cells in series.EPA testing documents for the Model 3 have appeared:
We also learn that it's "engine" is "normally aspirated" and that the battery is 221.81Ah with average voltage of 351V for total energy of 77.86kWh. This is in conflict with information from Senior Tinkerer @wk057 who stated confidently that the battery is 402V with 96 cells in series.
Yep you're right, I untagged the senior tinkerer so as not to draw his wrath.I think you missed one word in that: average voltage. So the fully charged voltage is 402, average is 351, discharged would be 300.
