No one. Military was looking at doing this for convoys 2 decades ago.Pure speculation but with the right software and hardware who needs drivers in the second and third trucks in the convoy.
About charging time:
Perhaps I'm missing something here, but is the speed of charging not determined by how fast a single cell can be charged. It does not matter if it is just one cell in a flash light being charged, or one cell among 8000; the rate of charge for each cell is the same. So, in my view this determines how fast one can charge either a single flash light battery or a 1,000,000W semi; the difference is just in the wiring.
Just want to clear up my language parsing.
Are you saying "the speed that an individual cell can be charged determines the pack charge rate"? (Interpeting statement as rhetorical question) If so, I agree.
No. Two 400 V packs of X amp hours in parallel or series is the same amount of energy and charge time is not affected.On the other hand you can do some tricks like putting more cells (or two 400 V packs) in series (so the charge current in each cell stays the same, but you get to a higher 800V pack voltage and thus more energy).
Yes and no
Yes, the bottleneck are the cells. On the other hand you can do some tricks like putting more cells (or two 400 V packs) in series (so the charge current in each cell stays the same, but you get to a higher 800V pack voltage and thus more energy). Also has the advange of lighter charge cables.
Nothing would stop you then from switching these packs that are in series during charging in parallel.
Guess I now just increased the confusion ?
“The company, folks, is going out of business,” Lutz said. At this rate they’ll never get to 2019.”
Correct. Some of the tweaking of cell chemistry going on since the last energy density boost might improve cell charging rate some amount, but probably not by a lot. That tweaking might also allow charging at a higher rate than now without degrading battery life.
Who the hell wants a super car to drive itself?!?!? And why mention a FSD semi now and scare off/piss off all the truck drivers?
That gives even more credence to this concept, as the military tech is at least 10 to 20 years ahead of what is currently available....No one. Military was looking at doing this for convoys 2 decades ago.
Thanks for the details. So, if I get this correctly, it is the battery chemistry that determines the charging speed, not the infrastructure or the configuration of charge ports etc.
Someone should teach Bob about the S curve.
