@cloudm Thank you so much for going the extra mile and figuring this all out! The smell returned in our car, so I'm back to buying another can of Kool-it and I can't wait to try this method!
Well I wasn't even close... Good thing I bought two of those cans lol. This is great instruction thank you!!
Yep that's what I did... Inserted the tip on the side of the fan near me then just spun it around... Even then it was a bit difficult but I think I got it. No smell so far.... I wish there was a quick way to even pull the fan off but that seems involved. There is also some kind of electrical plug just downstream of the fan outlet... There some wiring connected to it. I was thinking of removing that but it's too damn deep... I'm not even sure what it's for. You can see it in your earlier photos.. It's green/blue@gazepdapi @tnots -- my pleasure. cleaning our model X AC coil and ridding of this stench has been an urban myth for a while. I couldn't stand it anymore and wanted to get to to bottom of this.
Regarding the insertion of the tube, yes the fan blades keeps moving around. I was able to do it with one hand with gentle movements. If you push it too hard the fan blades can move around and change your insertion point.
Thinking of this, if I were to do it again. It might be better to insert the tip first (its the hardest part). Insert it where ever it's easiest. This can be the fan blade that is closest to you. Once the tip is in, rotate the blade so that the tip is positioned at the back. Then insert the rest down towards the left.
I had sometime this morning and found pics that break apart the AC dash assembly. I have notated the images to clearly show what we are trying to achieve. In the pics below, the AC coil has been removed so we can clearly see the inside of the chamber and how the foam should flow.
This one shows the insertion path and likely location of termination of the tip. The blue arrows show were we want to foam to go.
This shows how the foam should enter the AC coil housing chamber. In this pic, the coil was removed you no longer see the attached silver tube outlets that are directly connected to the ac coil. I just notated where the coil would be. You also clearly see the drain plug in the same chamber.
The chamford edges are designed to redirect the air from sideways from the blower to form a left turn and hit the coils perpendicularly directly.
I am sure this is the most effective way to apply the foam. If some of us are still experience the smell, it's likely because that the cleaning agent did not reach all of the coil areas or the cleaning agent did not have adequate time on the coils.
This can be remediated by
* Applying 2 cans back to back, the foam tends to climb on top of each other and expand. So we just need to increase the amount.
* Leave the foam to work longer. Increase from 15 mins to 30 mins. I think the drain tube position is very efficient meaning that we already see things dripping out after the 3-5 min mark. It's a sign that we didn't give enough time for the cleaning process.
Just used these instructions to clean my 2018 facelift Model S! Thanks!Here are the pictures and instructions after you have taking out the panels, glove box and the AC filter.
You will see the fan underneath the filter chamber. Insert the tube at the further most end of the fan well.
It's easier to insert the Kool-it black tip applicator through the top of the fan blades.
Insert it all the way in, we want the tip to go down towards the left as much as we can.
Apply Kool-it, if you did it right you should start to see the mixture excess dripping. When I applied it through the foot well air-outlet, there was no mixture seen under the car.
I see this asked a lot in Tesla forums, but really, Tesla buys their A/C units from some 3rd party manufacturer, so I don't understand why everyone thinks this is a Tesla specific issue. As if the point that Tesla technically only resells the A/C system and interfaces with it wouldn't be enough, why would multiple solutions for this problem exist and none of them specifically mention Tesla if this was a Tesla specific problem? I'm know I had this problem in a 2006 vehicle that definitely wasn't a Tesla, and I know that forums at the time had other people who had similar issues and workarounds that they also used for makes other than the one I had (it was probably an excessive option, one guy dropped his windows and ran his heat on high for the last few minutes of every drive where he had used A/C in order to dry out the evaporator before parking). Even back when I had this issue before there was any Tesla other than maybe a Roadster on the road, some mechanic shops had services available to rectify the issue (I think one of the products done by one of the mechanic shops was called FrigiFresh). The best explanation I saw for the issue was that a change in refrigerant requirements lead to the issue due to the necessary design for the new refrigerant. If that explanation is accurate, then there certainly was a time when this wasn't normal, but it was a long time ago.Why is it impossible for Tesla to get this right. I always thought this was just an issue with the 3, now I see it's on the S and X. I've never had a car that smells like my model 3 does when it's humid out and I've lived in Florida almost all my life.
That looks like a nightmare, and I hard it find to believe that it's "normal" based solely on your climate. In the interest of avoiding this issue (before anyone was even complaining about it because the 3 wasn't out yet, and while people were blaming COP, which I've never disabled), I've been trying to remember to turn off the A/C and keep the fan running for the last few minutes of my drive during the 3 seasons when A/C runs most of the time so that the air coming out isn't frigid anymore by the time I park. So far, I've had no smell issues, and Indiana is pretty humid in the summer. Additionally, in the interest of not having the HVAC run all night if a door randomly opens (which was firmware a problem in late 2017), I used to be in the habit of turning off HVAC completely every time I parked. FWIW, based on observation and intermittent failures in those practices, I don't think the fan blasts if you turn off the A/C and keep the fan running before stopping the vehicle, so turning off A/C off and keeping the fan running or fully turning off HVAC may help with your issue. That having been said, I still don't think your issue is being caused solely by Tesla's change to mitigate the issue combined with your climate. Do you know anyone else in FL with a Tesla and similar experience and/or have you brought your Tesla to service for this issue? If you don't know anyone and don't want to mess with service, you should at least make sure your condenser drain isn't plugged, because the amount of moisture necessary to do that may well imply that you're not getting any drainage at all.I respect that the parts may be manufactured elsewhere, but it's still within their control to either make changes to the design or find a manufacturer that will. From my own experience, the filter material sits directly against the evaporator. In Florida, that evaporator will always be wet when running and this leads to the introduction of water directly to the filter material, creating a suitable environment for bacteria, mold, and whatever else to grow.
Tesla has had years to fix or attempt to fix this issue.
In fact, their "fix" was to run the fan after shutdown. The problem with this is it delivers all the remaining moisture on the evaporator and within the HVAC system directly into the cabin. If it's raining outside or is significantly humid (like after a rain storm), when this program runs (say during a grocery shopping run), my entire cabin gets coated in a very thick layer of moisture by the time I return. I leave my windows down in my garage to let the moisture escape when the program runs if I drive through rain. You can literally draw faces on the leather armrest in the moisture on it. The attached picture is of moisture on the inside of the car, not on the outside of the windshield. Every surface is slick and wet. And yet, the stink still exists and now all my *sugar* is wet inside the car.
Long post with photos.
First off, thank you everyone for all of the great pics and discussion here. It really helped me understand how the filter, fan, and enclosures are arranged back there. I've been following this thread for some time and tried the procedure outlined here to fish the tubing through the fan blades. Although somewhat difficult to get that tubing to tuck in between the blades and into the chamber, I eventually got it down there. My first attempt at this several months ago (using Kool-It) seemed to have worked initially, but the smell soon came back. It wasn't too bad so we just sort of dealt with it for the time being.
Now with the recent record breaking hot weather here (Western WA) the vinegar smell came back with a vengeance! Like really bad. I had purchased this clean and protect kit from Amazon about a month ago, but never got around to using it until today. Just another option that I wanted to try. It's made by a company called DWD2. I have no affiliation with this company/product, just something I found through research. Amazon.com
What made this promising to me was how the product would be dispensed into the HVAC system. You do have to drill a small 3/16" hole into the plastic side of the enclosure between the evaporator and fan assembly, but this provides a more direct route to the evaporator. Also, the nozzle attachment at the end of the tubing is directional, meaning you can point the stream of foam cleaner towards the evaporator. After this process, I followed up with their protection coating product (it's a 2 step kit, but I think they can be purchased separately too). The protection coating is supposed to prevent odors from coming back and resists mold, mildew, and bacteria growth for 6 months (we'll see). It's definitely more expensive than a can of Kool-It, but if it truly works, I'm willing to use it in the future if needed. Plus, I now have a hole that can be used to dispense foam cleaner next to the evaporator.
This is just another option if anyone else wants to try it. I figured I would take some pics along the way in case it's helpful to others. It's too early to tell how well this worked, but I'm sure my wife will tell me right away if that awful smell comes back anytime soon (she drives the X more than I do)! Now for some pictures!
Location towards the back left of the fan/filter assembly. This is where we want to drill our small hole, as close as possible to the evaporator.
I didn't go too far to the left since I was concerned about wires and tubing in the way. The location I chose here was in a more "open" area. I used a wood screw to make an indentation to get the hole started and to help the drill bit stay in place.
Using a 3/16" drill bit and some extensions, I was able to reach in there and drill the hole. I would recommend vacuuming up as much of the debris as possible so the shavings don't fall into the enclosure.
This is the tip adapter that goes into the tubing. You can see the little part that bumps out on the circular section of the adapter, indicating the direction of the stream.
The tip fits snuggly into the 3/16" hole. Ensure the direction indicator is pointing towards the evaporator (pointing to the left).
And away we go.
Following their instructions, I let the foam cleaner sit for at least 15 minutes. Then I turned on the AC/fan for at least 5 minutes to clear out the system. I kept an eye under the car to make sure the drain hose was doing it's job (confirmed there were no clogs in the drain), and that there was a good amount of liquid coming out. At this point, I did move on and performed basically the same steps for their 'protection coating' solution. Once everything was done, I used their supplied plug to close up the hole. Pretty clean look in the end. I will say, the plug fits pretty tightly in there so you may have to pry at it a bit to get it out.
Packaging for the kit.
View attachment 679965View attachment 679966
I hope this is helpful for others or at least just provides another option. Let me know if anyone else has tried this. Just curious how it went for you...I'll also try to provide an update in the future with how well this worked. Really hoping this works better for the strong vinegar smell, gets pretty annoying and embarrassing especially if you're giving rides to friends/family..."what's that smell?!?!".
can you explain how to do your method. I would like to try to clean mine for the first time as this smell occasionally occurs in my model x.It's easier just take out the FET and use that opening, I think this is also the method service center uses. Ideally you want to take out the PTC heater, but that would make things more complicated (you need to remove knee airbag and do the proper electrical isolation on 12V and HV).
Sure, but a couple of things you should take note first:can you explain how to do your method. I would like to try to clean mine for the first time as this smell occasionally occurs in my model x.
