My rear near side window is slightly further back but all the door alignments look good. II hadn’t noticed it until your post but the seal is still good. I don’t think I’d worry too much unless the seal is compromised.So this is everything I have picked up so far.
Window alignment on both sides - What are people's thoughts; Am I being picky here? They look alright but not sure if I'm being super picky.
Roof glass alignment - one side is lined up whilst there's a miss match on the lines on the driver side. Is this normal? Surely, based on the size of the glass, there's likely to be some kind of misalignment as there will be overhang on one, the other, or both sides.
Windscreen graze - I've had a look at the glass and rub away some surface dirt and found a small chip. Would seem to be easily fixable by a windscreen repair dude but obviously it's a new car so I just want it checked out.
Rear light crack/imperfection - I spotted this before I'd even got in the car. the mark/crack is on the inside of the surface. the outside is smooth to touch.
I'm keen to get the views of others here on these issues.
Lastly, what route are people using to raise the defects/issues when it's a home delivery? Obviously if I'd have collected then I would have had longer to walk the car whilst at the SC and could have had a lot of things rectified then and there.
My roof glass is central with equal overhang. Again, unless the seal is compromised or it causes excess wind noise, or it irritates you, let it be. Windscreen and rear light definitely unsatisfactory but livable during lockdown unless a ranger can sort it.
