2021+ Model S and Model S Plaid Refresh Issues Thread
Model S LR 2021 Delivered 9-14-2021:
Missing Large rear trunk cargo cover. Per delivery specialist I spoke with on the phone: The cars are being delivered without the cover because the cover is backordered. It was not mentioned at the "hands free" delivery. I had to call to report the problem and was told about the delivery and backorder situation and to request the cover be ordered.
For those who are seeing large imbalance values, have you tried to charge to 100% *and let it continue to charge until it stops by itself*?
That's an understatement. Yes. But in my case the disparity is about 25%.
I range charged on my HPWC twice and did another from single digits to 100% at a V3 supercharger.
Made things worse. Lost range.
I should get the car back from the Service Center today with a reset BMS. Hopefully the BMS was just off from the factory and everything is ok now, or if I, in fact, have a bad pack, it will go bad over the next couple charge cycles. At that point, Tesla "will be monitoring" and hopefully a new pack will be in order.
This is the one of my issues as well. Since delivery I have yet to have the car stay at at the desired SOC I set. It always creeps up.
Along with that problem, my pack was only acting like a 70kWh pack. Meaning at 100% charge, I only see 259mi with 21" config.
Hopefully you are not seeing that as well, but have a look at your estimated range and calculate out your total available mileage.
If you DO in fact have an issue, there is 3 others like you on here. Me, @WilliamG & Dennis, (not sure his name)
Sadly, at this point there is no resolution. I get my ca back today after a BMS reset, so it might be ok, but I won't know until I cycle the battery a couple times.
So I got my car back from the SC.
The pack is representing a properly working Mid 90's kWh pack!
They told me they not only reset the BMS, but they also sent it some new software.
I will be doing a couple charge cycles this weekend, so hopefully it's going to be ok!
It would be the week after at a minimum. One week to get the button, another week for them to collect and review data before approving you.
yeah, I was more wondering if whatever FSD stack is running is eligible--I do not think that are any Palladium cars in the beta program now, and the stack running seems to be different than anything else.
Reactions: impastu and cwanja
I would suggest our low volume production cars are not in the cards, near term, for FSD beta. Tesla is trying to collect a lot of data, so they would likely prioritize the 3 and Y owners.
I have same message since I pu my car, but cannot do anything about it because SW stuck on 2021.11.102 and maps stuck on 2020.48. Message i have is navigate on autopilot needs maps update. Like a time warp.
Once I updated to 32.10, turned car off and left it overnight it returned. As to software. They pushed me an update Defoe the version I had and the next day the 32.10 hit.
just noticed this same issue on my car. I have FSD... it says connect to wifi to download updated maps, but when I do there is no option to actually use the wifi to update the maps. Still on an older FW version 2021.24.4
I had 24.5 freeze. The SC, reset the update. For 2weeks tried to push 24.4. During that time fsd quit. One night I had 24.4 show up as an update. After done I turned off vehicle in safety and the next morning it was restored. That night 32.10 showed up.
Reactions: impastu
