Daytonaviolet
how ? can you explain ?The new charging ECU and software redeploy from service mode can be the way
Last I checked this was a restricted part not available for sale. You’ll have to go to a Tesla certified shop, and none I checked with would touch an undamaged car. They have to put the VIN number in for the order, that part isn’t “allowed”. This info is over a year old though.Hello guys
Did someone tried to contact Tesla to order the housing for new lamps ?
It's a separate part what can be change based on tesla collision repair manual
View attachment 980364View attachment 980365
That would be awesome if this procedure will also work in model s. So your saying the car will detect the new ecu and automatically update the software?I will do this procedure soon.
Will replace taillights with charge port and will explain everything.
May be will implement something like bracket to install the new port in old housing.
I already changed the charging ECU on 2018 Model 3 to get a CCS.
The procedure is following:
1. Turn off the 12v battery
2. Disconnect the HV battery contactor by first responder loop
3. Change ECU
4. steps 2 and 1
5. Go to service mode and click on software reinstall and the new software will detect and install change ECU's and electronic components on the car.
I asked them for more detailsEVOffer posted this on Instagram...
they have a video about the lights. looks like they chop off a portion of the corner light and glue it back on so just FYI if you're interested in this mod that's why they call them 'refurbished'It looks like it's up on their website - $1500
Model S 2022+ Tail Light Upgrade Kit (For 2012-2021 Model)
This is incredible. A 2022+ Model S OEM Tail Light can now be installed on a 2012-2021 Model S! The kit comes with 4 refurbished 2022+ OEM Tail Light. The outer lights are modified to fit on older models with small charge port door. If you have a Type 2 charge port Model S and your charging...evoffer.com
We have the amber turns tied to the brakes in the pig tailEvoffer said they still working on solution got North America cars. Gahdamn elon!
Not available yet for North AmericaIt looks like it's up on their website - $1500
i believe there are working on a harness solution which would separate the brake/amber turn signals. but other option is to have someone update the config file. may just order evoffer and update config file.Not available yet for North America
For $750, you would think they would publish better pictures
Agreed. Im thinking about purchasing them.For $750, you would think they would publish better pictures
They should be. It’s the same wiring. I think they are being cautious about compatibility.Im curious how these wouldn't be compatible with the 2021 refresh models
