Big hint for peace of mind: forget the miles display and focus on percentageHas anyone with a recent delivery had a chance to test out the range or efficiency of the 60kwh 2022 model 3 with LFP batteries in this cold weather?
You’ll see much better efficiency if you pre heat too. My 55kw LFP is still doing 200-225wh/m with ambient 4 degrees. But if it’s cold that slips back to 270-280wh/m. City driving on a 32 mile commute. When I got it in Sep it was doing about 190wh/m at 14+ degrees.Has anyone with a recent delivery had a chance to test out the range or efficiency of the 60kwh 2022 model 3 with LFP batteries in this cold weather?
I'm sure he will start posting on the forum soonIt isn't really that cold yet, wait until the battery snowflake starts showing
When I pre-heat my LFP car, from the charger, it takes 7 kw of power from the mains. I guess it tuned for fast warm up...
I cannot adjust the current as it's not charging the battery when pre-conditioning. Also the cars at 100% SoC.Just a curious tangent. If you dial down the amps in the app, does it still use 7kW when pre heating, or might this be a way to reduce the amount of shore power the car uses at times when carbon generation is at it highest? I can't test as we have slow home charging, although I guess I could dial it down to 5A
Max draw only lasts for 3 mins. 5.9 kW after 5 mins ramps down to 4.6 kW.When I pre-heat my LFP car, from the charger, it takes 7 kw of power from the mains. I guess it tuned for fast warm up... So 3.5 kw will becoming from the afterburner with the remaining coming from the heatpump...
